mike avad 44 #1 Posted Friday at 08:48 PM Well i have my 6 inch P T O clutch plate on its way, how do you adjust that mine a manual I would like to get the info on this before it come's it's a 1972 wheel horse raider 12 and thank you for any reply, Share this post Link to post Share on other sites
Stepney 2,351 #2 Posted Friday at 10:15 PM Set the pto rod to the little divot in the center of the dash bracket, and then adjust the two lower nuts to push the loose clutch bell so it's just touching the friction pad. The inner nut should allow the clutch when far to the right to have an air gap, and have tension on the bar when pushed fully in to the left. ..Least that's how I remember adjusting mine last time I did, several years ago. 1 Share this post Link to post Share on other sites
mike avad 44 #3 Posted Friday at 10:40 PM OK got and thank you very much for your reply and have a good and safe weekend Share this post Link to post Share on other sites
