Don in Mystic
No Brakes in reverse!
Don in Mystic
I have a 1974 C-100. I recently relined the brake band with a new lining from Ebay. I used a high temp adhesive to attach it. The brakes work great when traveling forward but I have nothing in reverse. I skipped deglazing the "drum" but considering the brakes function perfectly in Fwd I doubt that's the problem. Any thoughts greatly appreciated.
rmaynard
So, there are two of us who sell brake linings on eBay. I can't speak for the other seller, but if you bought it from me, I can tell you that you probably just need to adjust your brake according to the manual. Of the thousands of linings sold, I have never heard of a reverse stopping issue. Try re-adjusting and let us know.
pfrederi
The band brakes used on wheel horses are self energizing going forward.  not so in reverse... so reverse braking will always be a bit weaker than forward.
  • Like 5
squonk
Paul is correct. Looking at the drum, it spins clockwise going forward. The band is tightened from the bottom and the drum surface is "forced" into the lining. In reverse the drum spins counter clockwise and is spinning away from the clamping force of the band
ri702bill
One other thing you may try - remove the brake band to give access to the brake drum. Scuff up the OD with 80 grit sandpaper. One creative person did this with a belt sander!!
This will give a rougher surface for the lining to "bite" into...
Ed Kennell
If Paul and Mike's theory is valid, My brakes should work best in reverse.
  • Haha 4
Don in Mystic
All good info and thank you. Re the picture, You must be Dutch!  I carry a boat anchor on mine when I do my big hill........
Edited by Don in Mystic
omitted something
  • Haha 2
squonk
Actually no. The forces acting on the wheel and brake are depicted by the arrows. where they meet is the most force. "self energizing"
8ntruck
:text-yeahthat:setup would be self energizing when in reverse.
