greyhound
walbro carb parts
greyhound
Hello All,  Have a 1971 kohler magnum 18 twin. Has a walbro WHG 60-2471 carburetor on it. Bought a new needle and gasket. I lost the throttle rod to the govenor. I can rig one up. Looking for a float bowl. It leaks at the bolt going thru the hole. Tried the grey gasket and it leaks . I tried the red one in the bag and it leaks too. Tried a little sealer on the washer and it leaks also. Looked at the bowl and tapped it with a hammer to flatten it out. Same trouble. Looked for a part number for a bowl , but came up empty handed.. Any ideas on where to look or buy one? Thank You All
gt14rider
Hi greyhound,  I just looked there's a mess of parts , float bowls and stuff,
I just typed (walbro whg 60- 2471 carburetor parts) bunch of kits. Hope it helps.:USA:
gwest_ca
Found 2 float bowls for the M18
One is 255448 and still available from Kohler.
The other is 2510401 and carried by Banta Saw so must be popular. Their listing gives the dimensions of it
They are located in Ontario Canada and carry mostly Stens parts. https://www.bantasaw.com/
Part #: 525-600
Description: Carburetor Bowl - Fits Walbro carburetors. Found on KOHLER engine. Size: 3/8" ID (Hole) X 2-5/8" OD X 1-1/4" HT
Catalog Page: 12-06
Retail Price: 9.85
OEM Name Part No.
Kohler 2510401
Kohler 2510401S
greyhound
Thank You again , will start searching
greyhound
UPDATE,    Well I was able to get a new fuel bowl and gasket for my whg 60  2471.  Thanks   My son was over and was looking at the aluminum fuel bowl. Come to find out it had a pin hole in the bowl. Nothing I did to make it leak. Seen on other older posting and other people had the same problems. Thumbs Up.
