mike avad 49 #1 Posted April 11 (edited) Are there 2 seals per side that go's on one tiller axle I have a tiller axle kit that has 5 seals it and one for the pully how do the 2 seal go on one axle on the tiller axel? Edited April 11 by mike avad mist type Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,844 #2 Posted April 11 The two seals go in back to back. The inner one goes in as normal - seal lip in to keep the oil in. The outer seal goes in backwards - seal lip out to keep dirt out. Good idea to place a wipe of grease between the seals so the outer one has some lubrication. If it is possible to leave a space between the seals for the grease even better. Does that answer your question? 2 1 Share this post Link to post Share on other sites
mike avad 49 #3 Posted April 11 I got it when I took the old seal out there was just one seal for each side and one for the pully thanks for reply got the job done Share this post Link to post Share on other sites
