peter lena 9,074 #1 Posted April 9 https://www.zoro.com/super-lube-4-oz-bottle-hydraulic-oil-118-iso-viscosity-85w-sae-51004/i/G5124506/?utm_source=channeladvisor&utm_medium=cse&utm_campaign=connexity&utm_content=17442280114770223921115681105008005&cnxclid=17442280114770223921115681105008005&tblci=GiAAyzVFQkecmpRBJd_HbZX7knA98H8--c4GGhcgv-Ib3CDK51koyfq817Tym-raATCp02M just did a re order , regularly use this in any cabling set up , also note temp range , extreme heat / cold used this for years at work , also food grade rated , perfect for O ring installation, great on any linkage set up , choke and throttle cables , move with little effort . all my cables have a spring to close set up , so there is always a spring assist in any movement , just experimenting , with long past issue , brought me to this fix , pete 1 Share this post Link to post Share on other sites
