Maynardb
H55 carb parts
Maynardb
Posted (edited)
Hi
im working on an H55 on my old suburban tractor and the float is bad. Does anyone know where I can get one either new or in good shape? Also a new bowl gasket and float needle valve? Pretty sure the carb is original so does that make it a tillotson?
thx
Edited by Maynardb
Achto
Maynardb
That carb would probably work but I’d have to change the choke lever setup and perhaps a few other things. The original carb is in good shape, minimal wear on the throttle shaft and adjusts well, just needs the float because it overflows after a minute. It has a pin hole in it
Ed Kennell
Will any of these work?
wallfish
Shake it and you should see the wet spot from gas. Heat the float with a heat gun or blow dryer with that hole facing down. The warm air will compress and push the gas out of the float. When it's empty, solder the hole.
WH H55s used different carbs depending on the year
I light the gas on fire and use that to heat the air and push it out but I'm not sure what other people are comfortable doing.
ri702bill
OK - where on the float is the hole located - it does make a difference.......
Maynardb
It’s along the top edge near the pivot point. I tried to solder it, which I did, but it must have stuff inside that I can hear rattling around so it doesn’t float as it should
  • Sad 1
Achto
That was just the first one that popped up when I looked, there are many more choices. For the price it might be worth getting one just to steal parts out of it.
Maynardb
Posted (edited)
Here’s pictures of it. It measures 1 15/16” od, 1” id and 5/8” thick. Any clue what might fit it?
thx
Edited by Maynardb
Ed Kennell
Can you use your carb numbers to research a part number?
