peter lena 9,074 #1 Posted April 6 https://www.google.com/search?q=stretch+wire+covering&rlz=1C1CHBF_enUS866US866&oq=stretch+wire+covering+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIHCAEQIRigATIHCAIQIRirAjIHCAMQIRirAjIHCAQQIRirAtIBCTExOTI3ajFqNKgCCLACAfEFChc9tjNhRvU&sourceid=chrome&ie=UTF-8#oshopproduct=gid:16911182459789499013,mid:576462678680080362,oid:11945260140200717221,iid:16034390776896538401,pvt:hg,pvo:3&oshop=apv&pvs=0 often refer to WIRE REROUTE , with cable wrap , these peel stick on , clean paint , or screw on as you go , letting you set up , improvement / correction to a trouble spot . imagine wiring in a cooler / not chafing spot ? shop around for best for you , pricing , availability . remember, a chronic problem is showing you the issue and the possible elimination of that problem , love those , make a change , pete 3 Share this post Link to post Share on other sites
kpinnc 13,655 #2 Posted April 8 I use this stuff all the time. Much better than the split wrap. Protects and organizes and won't hold all the dirt and moisture. 2 Share this post Link to post Share on other sites
Handy Don 13,333 #3 Posted April 9 Yep, great stuff but you do have to install it before connecting the wires! Share this post Link to post Share on other sites
