lynnmor
Diesel Oil Fans Information
lynnmor
Posted (edited)
I know that this video mentions direct injection quite a bit, but the basics should pertain to any type of diesel or gas engine.
Edited by lynnmor
HyperPete
Pretty awesome.  Ive been using Rotella in all of my motorcycles for decades.  Time to rethink this.
Thanks for the video!
squonk
Posted (edited)
I'm sticking with Rotella. Read the comments. Many folks have been using it for years like myself with great results. Direct injection engines are junk. Many fail with the "proper oil " When Honda and Toyota are having problems it's not the oil.
Edited by squonk
adsm08
The problem isn't direct injection, it's quality control and cost-cutting.
We have jacked the price of vehicles so high with fancy features like touch-screens, navigation systems, blind-spot/ADAS/Driver unawarness aides, etc that instead of ditching the BS they have slashed QC on the powertrains. Tolerances are too loose, and it causes issues like oil consumption.
Earlier DI engines that were built prior to those other events are fine. Look at how often the 2.0 Focus from 13-18 had actual engine issues.
1991Bills 520H
Thanks for the video, lots of interesting info there. I follow Lake Speed, Jr.’s Oil Geek channel all the time, but I must have missed this video. I’ve seen on other small engine chat rooms many users of the Shell Rotella diesel oil products in small gasoline engines without having any issues over many years of use and I’ve recently wondered about using Rotella T6, for example, myself. I started with running 30 W oil  (per the owners manual) in my 520H  for about the first 15 years (it only gets used in the summer in upstate NY). I then started using a full synthetic ever since, usually Castrol Syntec or Mobil 1. I haven’t had any oil consumption issues and engine continues to run well. When my 520H was mfg'd, full synthetic oils weren’t commonly used in small equipment which would be why TORO didn’t spec it in my manual back then. I’ve wondered what Toro or Onan (now Cummins) would currently specify if they were to update manuals (not likely for out of production equipment). Does anyone here know if there’s any newer manufacturer oil specs for Onan engines?
Bill D
I run Mobil 1 10W-30 in all my equipment.  No issues so far.  I can get it at BJ'S for $32 plus tax for 6 quarts.  Best price I've found.
HyperPete
You need to visit the jungle:
https://a.co/d/7sKZ7It
johnnymag3
Rotella 30w...............Amazon  :) Buy the case !!!!
8ntruck
Interesting.  But, mostly aimed at current diesel and gas automotive/truck engines, not old small engines.
I'm going to guess that our old small engines operate at lower stress levels and don't get as many operating hours as the current automotive/truck engines referred to in the video, so they won't be as sensitive to the additive package in whatever oil is used.
I'm still of the opinion that the current automotive oils are optimized for roller cams and the current journal bearing materials and coatings - which is not what is inside of our Kohlers and Onans.  I'll opt for the added zinc in the oil for my horses.
