b00mhower
Front Wheel "Upgrade"
b00mhower
Hello all, with the change in weather the ole horse has come out of the stable.
 Still have delusions of grandeur about making a front scoop out of my existing plow frame and I fairly quickly realized I need a touch more ground clearance. I know folks have adapted trailer hubs for the front but as I no longer have a machine shop at my disposal elected for another solution
Que marketplace. Found a fella selling a pair of Cub 154 Lo Boy front wheels and tires for pretty decent $ so I jumped on it. $25 worth of bushings from McMaster later and viola 4-12 front end on a 312.
That's pretty much it, it leans a bit but it's not for show, maybe I'll put 24's or 6-12 on the rear to straighten it up but I don't really mind for now.
adsm08
So? Haven't you seen any of the trucks owned by some sub-25 nutbags? That look is all the rage.
  • Haha 1
b00mhower
Unfortunately I have lol as a recently reformed sub-25 nutbag I can at least say this was for functional reasons
  • Haha 4
ebinmaine
Looks good from here ...
That's the same basic lean back my own C160-8 Cinnamon Horse has.
b00mhower
If I recall correct you were the one who pointed me in the 12" front wheel direction. Finally got around to it
Wild Bill 633
Its called the "Carolina Lean."
Edited by Wild Bill 633
ri702bill
Nice!! Those front wheel plates look to have the square cut holes for rear wheel weights.... just a thought.
b00mhower
Had the same thought. Gotta wait for it to dry up some but I'm gonna see how they do disking the garden, pulling the moldboard with the old tires at times I was steering with hopes and dreams
  • Haha 3
ebinmaine
Not the best method.
:lol:
That's why I leave the Mackissic chipper shredder on the Cinnamon Horse all year.
HUGE front weight there for a heavy stuff pulling rear hitch counter balance.
  • Haha 1
b00mhower
:lol:
There's one of those things the green tractor guys got right, steering brakes. I've serviced more older deere GT's than I'd care too but the turning brakes really make a small tractor feel big
HyperPete
My 414 does that!
  • Haha 6
953 nut
Who the heck coined the phrase  Carolina Lean?               :angry-tappingfoot:           Ain't seen nothin like that in my neck of the woods!
Living in the mountains of Western North Carolina I can see where this could work well coming DOWN many of our steep grades but it might want to do a backflip on the uphill grades.
I feel that it is the obligation of each younger generation to try to piss off the older generation; Lord only knows I did my part a few decades back! Then  again,  its nothing new, just a recycling of the 1960's GASSERS minus the horsepower.
1000hp 8sec '57 Belair Gasser! Special Feature: RUNNING ON EMPTY - YouTube
  • Haha 2
ri702bill
I improved the steering for the winter by changing to ag tires, fluid filling the inner tubes, and adding 25 lb barbell weights to the fronts.... (1st year with the C81 - used turf tires...) I find the prices for the WH cast weights would probably require me to name my next kid after the seller...!! :o
P1010130.JPG.8a8c42324976d9152cd3e30e7080202f.JPGP1010325.JPG.03ef569129bfb712b35d442da1287785.JPG
b00mhower
I hadn't put much thought into front tire weight but after this past winter of getting taken for a ride trying to plow the drive I might give it a shot. I've got the rears loaded but no bolt on weights
ri702bill
Additional weight - on or in the wheels is the best solution to prevent premature wear of the axle bearings. Because the rims are wider on the C series, I use 95 lbs of cast iron weights in the rear - a handfull to install, but worth it...
ebinmaine
Agreed.
I installed oversized tires front and rear to get extra fluid capacity.
Also installed Bolens weights in the rears because they're heavier than average.
My fluid is 255 to 260 lbs ALONE.
b00mhower
Looks like fluid fill with these tires would gain me 15-20lbs. I had an idea about casting my own concrete weights so I may go on ahead and try that, luckily I have some calc'ed out rears to use for a template
kpinnc
Right????
Must have come from South Carolina... :rolleyes:
  • Haha 1
adsm08
It is an abomination of physics and geometry.
8ntruck
I saw one of those taildraggers while we were in California last week.  I think it was a Tahoe.  With that short wheelbase and high rake, I was wondering how much of the road ahead the driver could actually see.
  • Haha 2
Handy Don
IMHO, fashion and fads often have little or nothing to do with function.
  • Like 4
