Gilou15
Sundstrand or eight pinions diff ?
Gilou15
Posted (edited)
Salut les gars !
J'ai deux choix aujourd'hui :
-Une 416 huit vitesses 1000€ (P216)
- Une C161 Auto 1300€ (K341)
Que pensez-vous de
En France c'est rare et cher...
Edited by Gilou15
ebinmaine
Given the choice between the two I would choose the C160 as long as you're okay with hydros.
That will be a great tractor with a great transmission and also a hydropowered lift mechanism.
A 416 and a C160 are both great choices.
Blasterdad
:handgestures-thumbupright: :auto-layrubber::auto-checkeredflag:
  • Confused 1
953 nut
Hi guys!
I have two choices today:
- An eight-speed 416 for €1,000 (P216)
- A C161 automatic for €1,300 (K341)
What do you think of...
In France, they're rare and expensive...
In my opinion the 416 would be the better choice especially if it is a 1987 or 1988 which has the Kohler engine. The eight speed transaxle tends to be trouble free for much longer.
À mon avis, le 416 serait le meilleur choix, surtout s'il s'agit d'un modèle de 1987 ou 1988 équipé du moteur Kohler. La boîte-pont à huit rapports offre généralement une durée de vie beaucoup plus longue.
Blasterdad
@Gilou15 The P216 is an Onan engine
I have never had ANY problems with my Hydro Transmissions. I have that same tractor, it's a beast & one of my favorites.
IMG_1786.MOVFetching info...
kpinnc
Go with the C-161. Onans are good engines, but can be fickle and repair parts are expensive if you find them at all.
  • Sad 1
Gilou15
Thanks for all yours answers!
It is a Toro power plus (Onan )on the 416 ....
For the 161 : is there a difference with a 160 ?
However,I would prefer Eaton than Sundstrand..and the diff 10 pinions is it reliable ..Is it really limited slip ??
ebinmaine
Early Sundstrand, up to 1971 maybe, had the 10 pinion Limited Slip Differential.
I'm quite sure from 1974 up which is what a C160 (1974 to 1977) or C161 (1978 +)  could be, has the Heavier Duty well-known 8 pinion.
Lee1977
Posted (edited)
Last two runs of the 10 pinion was a early 1973 Raider 12 Model 1-0350 and a 1973 14 HP no name Model 1-0340 according to the list I have.
Edited by Lee1977
  • Excellent 2
Gilou15
Yes ! probably a C161 has 8 pinions diff in 1978 !
ebinmaine
Certainly should
Gilou15
Wonderful collection !!
