Thetbone 28 #1 Posted March 18 Taking apart my 1993 520h, I had a question? What does everyone do with all the bolts, screws? Do you get all new, some are not in great shape, some are. Do you use all stainless? Thanks Share this post Link to post Share on other sites
ebinmaine 70,524 #2 Posted March 18 We use nearly all new Grade 8 hardware from Bolt Depot in Hingham MA. Service is excellent. Pricing is excellent. We also use a Nyloc nut on as many bolts as possible. This is likely not needed for most but have very hilly twisty terrain and have had bolts snap or come loose. I personally don't use stainless because they tend to gall and strip when tightening with an impact driver. Grade 8 gives us good corrosion resistance and of course, strength. 2 Share this post Link to post Share on other sites
Thetbone 28 #3 Posted March 18 Thanks for the help, much appreciated. 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,376 #4 Posted March 18 If it's in good shape, clean it up and reuse. If not, replace. Only exception - I always use new lock bolts on hubs. 3 Share this post Link to post Share on other sites
ebinmaine 70,524 #5 Posted March 18 21 minutes ago, SylvanLakeWH said: If it's in good shape, clean it up and reuse. If not, replace. Only exception - I always use new lock bolts on hubs. Oohh yes. Set screws. We always use new set screws. There'll be some in the hubs, maybe a couple pulleys. Share this post Link to post Share on other sites
moe1965 752 #6 Posted March 19 (edited) I always put never seez on my bolts it makes it easier for the next guy when he takes it apart LOL Edited March 19 by moe1965 1 Share this post Link to post Share on other sites
953 nut 57,740 #7 Posted March 19 15 hours ago, Thetbone said: What does everyone do with all the bolts, screws? Do you get all new, some are not in great shape, some are I tend to reuse all fasteners that are in good condition. In my opinion the American Made hardware from the 1960s is far superior to the foreign made stuff you buy today. 6 Share this post Link to post Share on other sites
ebinmaine 70,524 #8 Posted March 19 24 minutes ago, 953 nut said: In my opinion the American Made hardware from the 1960s is far superior to the foreign made stuff you buy today. Absolutely agree with that. That's why I use the source that I do. Some of the stuff is marked made in USA and it is all high quality. 2 Share this post Link to post Share on other sites
Thetbone 28 #9 Posted March 19 All very helpful, thanks again. I know I will have many more questions. 1 Share this post Link to post Share on other sites
Thetbone 28 #10 Posted March 23 And it begins... 3 1 Share this post Link to post Share on other sites
Thetbone 28 #11 Posted March 23 I am learning as I go, can't call this a total restoration, more like clean, re-paint as needed, replace as needed. 4 Share this post Link to post Share on other sites
Thetbone 28 #12 Posted March 23 I'm not a big picture taker, I will do my best! Had minor surgery so I won't have progress until next weekend. I will need a newer hood, any suggestions on where to find that? I have searched Ebay but not much. 2 Share this post Link to post Share on other sites
ebinmaine 70,524 #13 Posted March 23 5 minutes ago, Thetbone said: I'm not a big picture taker, I will do my best! Had minor surgery so I won't have progress until next weekend. I will need a newer hood, any suggestions on where to find that? I have searched Ebay but not much. An ad here in Redsquare is a great start. Also PM @76c12091520h Brian Badman Or @Jake Kuhn Or CALL Lincoln at A to Z Tractor in PA 2 Share this post Link to post Share on other sites
Thetbone 28 #14 Posted March 23 Thank you sir, much appreciated. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,524 #15 Posted March 23 1 hour ago, Thetbone said: Thank you sir, much appreciated. Glad to help. Just keep asking questions. Whatever you run into, someone here has already seen and solved it. 2 Share this post Link to post Share on other sites
Brockport Bill 1,821 #16 Posted March 23 depending on the rehab and the extent of the cleaning, painting etc -- i ofen use new bolts -- but if not new --- i tend not to want to use old rusty bolt heads especially if doing any painting -- but what i will often do is buff the bolts - only takes few minutes --- cleaning any rusty threads with wire wheel --- but also buffing the heads to nice shine -- saves the old bolt but gives newer shiny look on the tractor 4 Share this post Link to post Share on other sites
oliver2-44 10,323 #17 Posted March 24 I also buff old bolt is bench grinder eire wheel. Clamp them in a vice grip to do the threads, then screw a nut on and do the head. Lots of quality shop time. Wear safety glasses and a dust mask. I then raffle can paint them or clear coat them. 3 Share this post Link to post Share on other sites
Thetbone 28 #18 Posted March 24 Thanks, all great advice, much appreciated. 1 Share this post Link to post Share on other sites
Thetbone 28 #20 Posted March 31 Pulled some more of the metal off. 2 Share this post Link to post Share on other sites
Thetbone 28 #21 Posted March 31 Unfortunately I am running out of time, this is what I use to mow my yard, 1 acre. I think my goal is to clean everything, not repaint items. I'll clean all the nuts and bolts good, replace as needed. What I do need is to fix the seat and figure out why the tractor has a hard time starting. 2 Share this post Link to post Share on other sites
SylvanLakeWH 27,376 #23 Posted March 31 I put a marine primer bulb on my C-105 to help with starting. A couple squeezes and it fires right up... just a thought... 4 Share this post Link to post Share on other sites
ebinmaine 70,524 #24 Posted March 31 6 minutes ago, SylvanLakeWH said: I put a marine primer bulb on my C-105 to help with starting. A couple squeezes and it fires right up... just a thought... Definitely recommended. 1 hour ago, Thetbone said: why the tractor has a hard time starting. I'm no Onan expert. At the very least do: New spark plugs. ALL new fuel line New filter(s) Primer bulb Clean out carb (rebuild?) Carefully check intake manifold for vacuum leaks. Carefully check fuel pump for proper operation. Remove and clean out tank. 2 Share this post Link to post Share on other sites
Horse Newbie 7,195 #25 Posted March 31 On 3/23/2025 at 9:32 PM, oliver2-44 said: I also buff old bolt is bench grinder eire wheel. Clamp them in a vice grip to do the threads, then screw a nut on and do the head. Lots of quality shop time. Wear safety glasses and a dust mask. I then raffle can paint them or clear coat them. I wire wheel, buff original hardware also. Saves a few coins and I just prefer to keep what I can from each tractor. 1 2 Share this post Link to post Share on other sites
