702854boy
Voltage Regulator Questions
adsm08
2 minutes ago, pfrederi said:
With a S/G you polarize it every time you try to start it.  Polarization is only important for a generator.
The regulator manufacturer says to do it. And those books were written back when the people writing them knew what they were doing.
Handy Don
14 hours ago, 702854boy said:
When we rewired it, we took the wires from the ammeter, removed them and ran a wire from the middle terminal on the voltage regulator to the battery, and it was working fine until January and then when we went through the starter, it was working without problems until yesterday.
There are no shortcuts. You’ve gotten good advice, follow it.
pfrederi
The say to do it because the regulators were more frequently used on plain generators in cars not S/G.  The car generator only type do need to be polarized.
702854boy
I did that grounding test that was mentioned and engine did not bog down any, I had it at about 3400 rpm, voltage stayed at 12.30
adsm08
That is a sign that the generator is still not working correctly.
Handy Don
:text-yeahthat:
pfrederi
Charging field coil could be bad.
  • Excellent 1
Handy Don
Posted (edited)
Internal short in the winding, I’d wager, but could also be that the connection to the external post is bad.
Edited by Handy Don
lynnmor
Posted (edited)
While several mentioned seat switch, that doesn't necessarily mean the switch is bad, it might be the connection, adjustment or some other mechanical problem.  Try jumping the switch for a test.
Somehow I posted this to the wrong thread, disregard.
Edited by lynnmor
goofed
  • Haha 1
702854boy
I do not think it would be the seat switch as it does not have one, it was made before OSHA took control of everything.
