dmoore 944 #1 Posted Monday at 11:37 PM Anyone make some sort of adapter for sleeve hitch on my 64 854 to be able to tow cart, wagon and pivot, turn? Share this post Link to post Share on other sites
Achto 28,359 #2 Posted yesterday at 12:19 AM (edited) A flat piece of metal, at least 1/4" thick ( up to 5/8" ) with 2 holes drilled in it works well. 1 hole to hold it in the sleeve hitch and one for your hitch pin. I have made several. Edited yesterday at 12:38 AM by Achto 4 Share this post Link to post Share on other sites
ri702bill 8,821 #3 Posted yesterday at 12:20 AM (edited) I run the later style welded one on my 854.... some folks run both at the same time... Edited yesterday at 12:21 AM by ri702bill 2 Share this post Link to post Share on other sites
dmoore 944 #4 Posted yesterday at 12:36 AM Thanks, I was wondering what Wheel Horse used when tractors were new. Share this post Link to post Share on other sites
WHX?? 50,087 #5 Posted yesterday at 12:42 AM (edited) 9 minutes ago, dmoore said: used when tractors were new What Dan showed. Just guessing a draw bar was also a desirable option in the day since there is a ton of them out there. I like to run a regular draw bar and a sleeve. In our business we seldom use a sleeve except on plow mules. Edited yesterday at 12:48 AM by WHX?? 1 3 Share this post Link to post Share on other sites
dmoore 944 #6 Posted yesterday at 12:47 AM Didn't think about that hitch..he'll I've got 3 or 4 somewhere. Thanks WHX! 1 1 Share this post Link to post Share on other sites
WHX?? 50,087 #7 Posted yesterday at 12:52 AM 4 minutes ago, dmoore said: Thanks WHX! Your 1 Share this post Link to post Share on other sites
953 nut 57,034 #9 Posted 14 hours ago I have cut down one end of a scrap piece of 2" channel iron and bent it to allow a hitch with a ball to ride a bit higher using the sleeve hitch in the up position. 7 1 Share this post Link to post Share on other sites
WHX?? 50,087 #10 Posted 11 hours ago 2 hours ago, 953 nut said: allow a hitch with a ball to You can't do that Richard ... Not sorry but the rules are quite clear... and you of all people should know this. If a ball hitch is desirable one must obtain another horse dedicated with a permanently attached ball for such use. Preferably a round hood... 2 1 Share this post Link to post Share on other sites
Handy Don 13,143 #11 Posted 11 hours ago 2 hours ago, 953 nut said: I have cut down one end of a scrap piece of 2" channel iron and bent it to allow a hitch with a ball to ride a bit higher using the sleeve hitch in the up position. This one is on my 854 as I type! 😉 When putting a ball on a slot or clevis hitch it is good to remember that trailer forces can lift the hitch unexpectedly. Also, having a lifted blower or dozer blade while also putting a trailer on the hitch puts the weight of both implements onto the center rock shaft and, for non-hydros, on the lift lever latch. 1 Share this post Link to post Share on other sites
sergeant 306 #12 Posted 10 hours ago (edited) Here is what I use On any of My sleeves: integral hitch and clevis hitch, whatever the Manufacturer calls it. https://johnnyproducts.com/products/generic-multi-tongue-to-sleeve-hitch-towing-adaptor-attaches-to-any-sleeve-hitch-on-your-tractor-fits-elitewill-nixface-nubehone-craftsman-cub-cadet-and-other-sleeve-hitches-black Do You have a slot Hitch or clevis Hitch ? If You Just have the slot Hitch add this https://wheelhorsepartsandmore.com/product/toro-wheel-horse-slot-hitch-adapter/ Plus John's adapter Edited 10 hours ago by sergeant 2 Share this post Link to post Share on other sites
peter lena 9,023 #13 Posted 10 hours ago @sergeant like the idea of adapting to a problem , for my set ups , going over to a ball hitch , lets me tandem and or quick switch , just back up , push the cup down / ball , lever lock , go , also did that same idea on problem elimination , my 3 horses are set up the same way , with used to be chronic issues , verify the fix / change , to problem , then adapt to other tractor . pete 1 Share this post Link to post Share on other sites
squonk 42,056 #14 Posted 4 hours ago Always have both style hitches on the rear. Cheap and flexible. Then add a front mount for trailer moving! Share this post Link to post Share on other sites
