dmoore
Towing with sleeve hitch
dmoore
Anyone make some sort of adapter for sleeve hitch on my 64 854 to be able to tow cart, wagon and pivot, turn?
Achto
A flat piece of metal, at least 1/4" thick ( up to 5/8" ) with 2 holes drilled in it works well. 1 hole to hold it in the sleeve hitch and one for your hitch pin. I have made several.
Edited by Achto
  • Like 4
ri702bill
I run the later style welded one on my 854.... some folks run both at the same time...
Edited by ri702bill
dmoore
Thanks, I was wondering what Wheel Horse used when tractors were new.
WHX??
What Dan showed. Just guessing a draw bar was also a desirable option in the day since there is a ton of them out there.
I like to run a regular :wh: draw bar and a sleeve.
In our business we seldom use a sleeve except on plow mules.
Edited by WHX??
  • Excellent 3
dmoore
Didn't think about that hitch..he'll I've got 3 or 4 somewhere. Thanks WHX!
WHX??
4 minutes ago, dmoore said:
Thanks WHX!
Your :text-welcomewave:
ri702bill
:text-yeahthat:!!
953 nut
I have cut down one end of a scrap piece of 2" channel iron and bent it to allow a hitch with a ball to ride a bit higher using the sleeve hitch in the up position.
  • Like 7
WHX??
You can't do that Richard ... Not sorry but the rules are quite clear... and you of all people should know this.
If a ball hitch is desirable one must obtain another horse dedicated with a permanently attached ball for such use.
Preferably a round hood...:lol:
  • Haha 1
Handy Don
I have cut down one end of a scrap piece of 2" channel iron and bent it to allow a hitch with a ball to ride a bit higher using the sleeve hitch in the up position.100_4749.JPG.bf0904d3df102866b50dc08511403c80.JPG
This one is on my 854 as I type! 😉
When putting a ball on a slot or clevis hitch it is good to remember that trailer forces can lift the hitch unexpectedly.
Also, having a lifted blower or dozer blade while also putting a trailer on the hitch puts the weight of both implements onto the center rock shaft and, for non-hydros, on the lift lever latch.
sergeant
Here is what I use On any of My sleeves: integral hitch and clevis hitch, whatever the Manufacturer calls it.  https://johnnyproducts.com/products/generic-multi-tongue-to-sleeve-hitch-towing-adaptor-attaches-to-any-sleeve-hitch-on-your-tractor-fits-elitewill-nixface-nubehone-craftsman-cub-cadet-and-other-sleeve-hitches-black
Do You have  a slot Hitch or clevis Hitch ?
If You Just have the slot Hitch add this https://wheelhorsepartsandmore.com/product/toro-wheel-horse-slot-hitch-adapter/  Plus John's adapter
Screenshot 2025-03-11 at 10-31-19 Multi Tongue Hitch Adapter Tractor Sleeve Hitch to Trailer Connector – Johnny Products.png
Edited by sergeant
peter lena
 @sergeant  like the idea of adapting to a problem , for my set ups , going over to a  ball hitch , lets me tandem  and or  quick switch , just back up ,  push the  cup down / ball , lever  lock , go ,  also did that same idea on problem elimination , my 3 horses are set up the same way , with used to be chronic  issues , verify the  fix / change , to problem , then adapt  to other tractor . pete
squonk
Always have both style hitches on the rear. Cheap and flexible. Then add a front mount for trailer moving! :banana-wrench:
