BdubRADR12
1968 Raider 12 missing transaxle drain plug
BdubRADR12
First, I apologize if I missed a already existing thread about this topic.
I've been taking my raider apart and tipped it up to pressure wash all the grease off, and I noticed a open threaded hole in the bottom of the transaxle. I could only assume its for the oil drain. Can anyone confirm this and direct me in finding a replacement? I believe its a #5060 limited slip 10 pinon.
Blasterdad
:scared-eek: Yes, that is the drain plug. Hopefully it didn't do any damage to it. There's nothing really special about it, just a 1/4" allen pipe plug.
Its number 65 in the IPL.:handgestures-thumbupright:
Dorman 02472: Dorman Pipe Plugs
ri702bill
Use the "hollow hex" style shown, not the more common one with the protruding square. You want it to be flush with the Unidrive case....
peter lena
@BdubRADR12  personally like a  HI MILAGE ATF  fluid for a flushing / cleaning agent , nave any  safe open road driving spots around you ? like a CUL DE SAC ? , like to put miles / time on that cleaning oil , also new shift boot . also when you drain that oil out  its good to lift up the front end , higher  off ground , couple of jack stands , safety , makes for more thorough  drainage . also like CLIMBING gear oil , read specs , 75x90 , easier filling with   shift boot removed , use every gear / range , also LUBRICATE  EVERY MOVEMENT LINKAGE  point , like penetrating oil first , make the rust run out , then aerosol red grease , take off shifter plate , and lube in there also , look for bronze end bushing areas , behind dash , make connections  work with ease , gold mine , pete
  • Excellent 1
peter lena
@oldlineman  thank you for that !   tend to go  well over the original intent , do not like the idea of a  SPOT FIX , typically there  are close related  movement areas , that lower console spot , bottom of  dash area is often neglected , and also filled with rusty binding connections  , to  improve on , another  GOLD MINE  of improvement  zone . the  lift lever  zone alone ,is  known for , sloppy connection , and no lubrication , when washered up and red greased , knock r loose, penetrant , related parts actually , function . all my trans oils are full and clean , being an old line man yourself , you know what a call in failure is like , you correct things , while you are in the area , coming back at 3 am , will make you do that , just talking , pete
BdubRADR12
Very helpful thank you, I also noticed today I'm missing the drive pulley key for the shaft keyway, what should I do about that?
Blasterdad
You should be able to find both the plug (probably in plumbing fittings) & key in the Hillman drawers at your local hardware store or Tractor supply...:handgestures-thumbupright:
  • Similar Content
    • 87buickt
      By 87buickt
      Newb here, recently purchased a b310 that now runs with snow thrower, plow, and mower deck for what I believe to be a good deal for $200. My question to all y’all gurus is what am I missing for my snow thrower attachment? I’d like to get it squared away before winter I know I’m going to need a belt and chain any help would be greatly appreciated.
    • Blackhood Bill
      By Blackhood Bill
      Ok guys I have a question but I need to give some background. I have a 1 car garage & a shed full so my project the gt1800 while have to wait until summer (maybe). With that being said when I do get into tearing the horse down for rebuild I was wondering what some of you do with the hardware until you actually start putting it back together. Example hood bolts to hinge, hinge bolts to frame. My questions do you store them in the piece you take off or do you label a small bag and store them in a container of some type?
    • Stillwaters
      By Stillwaters
      Hello! I am new at the Red Square and it's good to be here!  I have a 310-8  with a 46" deck  and I need new mounting hardware for my wheels and rollers.  I am having difficulty finding the items simply without spending a bunch...I've contacted the place that had the .  Does anyone offer a kit for just the hardware (the wheels and rollers are newer)?  Where have you guys found such hardware? Thanks for your time!
