peter lena
choke and throttle cables , like this
peter lena
https://www.super-lube.com/super-lube-wire-rope-2   check out the temp  functional range , local h/w  stores or on line . liquid form , pete
Achto
In my experience Super-lube works well metal to metal or to coat electrical fillings with to keep corrosion at bay. It does not fair well with rubber or plastic coatings, seems to actually get sticky in those applications. With some cable sheathing having a plastic liner in it, I would be a bit leery of using it on cables.
Prefer PJ1 cable lube myself.
https://www.amazon.com/PJ1-1-12-Cable-Lube-Aerosol/dp/B00HRXOGVW/ref=asc_df_B00HRXOGVW?mcid=05443524fbbd37c093595c3749f1e3db&tag=hyprod-20&linkCode=df0&hvadid=693606727669&hvpos=&hvnetw=g&hvrand=2670779049480939346&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021712&hvtargid=pla-571238522095&th=1
One of these works well to help force the lube into the cable casing.
https://www.amazon.com/Motorcycle-Lubricator-Motorcycles-Bicycle-Scooter/dp/B0C8GBW271/ref=asc_df_B0C8GBW271?mcid=2ca30030b2ab3b22b9bc9410d872b6bf&tag=hyprod-20&linkCode=df0&hvadid=693338692942&hvpos=&hvnetw=g&hvrand=7788745433652530525&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9021712&hvtargid=pla-2281152264467&th=1
peter lena
 @Achto  never had an issue with it , on any cabling , also have extension springs , on all my related cable linkage  , smooth easy  function , do what ever you like , pete
