Retired Wrencher 6,612 #1 Posted March 5, 2025 What do you guys use to check Rpm`s. They have a laser type that makes it easy to use. Also I have my old automotive type but made for 6 and 8 cylinder engines. Any ideas are welcome. Share this post Link to post Share on other sites
Achto 31,674 #2 Posted March 5, 2025 35 minutes ago, Retired Wrencher said: What do you guys use to check Rpm`s. this is what I use. https://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html?utm_source=google&utm_medium=cpc&utm_campaign=21901739405&campaignid=21901739405&utm_content=173216750591&adsetid=173216750591&product=66632&store=820&gad_source=1&gclid=EAIaIQobChMImP_k9vLyiwMVtTatBh2mAARXEAQYASABEgKOvvD_BwE 2 2 Share this post Link to post Share on other sites
WHX?? 56,315 #3 Posted March 5, 2025 Avoid the cheapest in the jungle if possible. Not than they are all junk like the one I have. It works... when it feels like it and even then erratic. Read the reviews and advice from others here if they have one. Most are laser type with a piece of reflective tape stuck on the fly wheel (non contact) Some are convertible with a rubber tip to read right off the crank. Share this post Link to post Share on other sites
OoPEZoO 594 #5 Posted March 5, 2025 I use a free downloaded video tachometer app on my phone. It uses the built in camera flash and adjusts the shutter speed to match the RPM. It works great and its always in my pocket. 7 1 Share this post Link to post Share on other sites
oliver2-44 11,436 #6 Posted March 5, 2025 2 hours ago, OoPEZoO said: I use a free downloaded video tachometer app on my phone. It uses the built in camera flash and adjusts the shutter speed to match the RPM. It works great and its always in my pocket. 1 Share this post Link to post Share on other sites
ri702bill 11,979 #7 Posted March 5, 2025 5 hours ago, Achto said: this is what I use. https://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html?utm_source=google&utm_medium=cpc&utm_campaign=21901739405&campaignid=21901739405&utm_content=173216750591&adsetid=173216750591&product=66632&store=820&gad_source=1&gclid=EAIaIQobChMImP_k9vLyiwMVtTatBh2mAARXEAQYASABEgKOvvD_BwE I also - reflective tape on the engine pulley shaft on the 854, on the PTO Bell on the C81 (with PTO engaged). Works best in the shade, will NOT work in direct sunlight. 1 Share this post Link to post Share on other sites
wallfish 19,845 #8 Posted March 5, 2025 Most of the time it's one of these old school tools. 1 7 Share this post Link to post Share on other sites
Racinbob 12,921 #9 Posted March 5, 2025 That's me too John. At least on the idle. I don't recall actually ever checking that. I go low until it feels too low than up just a touch. The same is kinda true for the top too. If it seems a bit high I back down a fuzz and then actually check it. 2 1 Share this post Link to post Share on other sites
squonk 46,256 #10 Posted March 5, 2025 3 hours ago, wallfish said: Most of the time it's one of these old school tools. Had a guy named Tony in the shop with ears like that. We called him "Cave Ears" Share this post Link to post Share on other sites
stevasaurus 23,670 #11 Posted March 5, 2025 The ear does not lie...and it works for adjusting the carb also. In fact, I can do tire presure too. I'm just a walking "Sun" machine. I can tell you which lifter is bad in a car engine, which bearing is good or bad in a transmission, where in the ground the point from a boring machine is, and when a woodpecker is pecking at my T-111 garage siding. 3 Share this post Link to post Share on other sites
oliver2-44 11,436 #12 Posted March 6, 2025 3 hours ago, stevasaurus said: The ear does not lie...and it works for adjusting the carb also. In fact, I can do tire presure too. I'm just a walking "Sun" machine. I can tell you which lifter is bad in a car engine, which bearing is good or bad in a transmission, where in the ground the point from a boring machine is, and when a woodpecker is pecking at my T-111 garage siding. 3 Share this post Link to post Share on other sites
Retired Wrencher 6,612 #13 Posted March 6, 2025 22 hours ago, Achto said: this is what I use. https://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html?utm_source=google&utm_medium=cpc&utm_campaign=21901739405&campaignid=21901739405&utm_content=173216750591&adsetid=173216750591&product=66632&store=820&gad_source=1&gclid=EAIaIQobChMImP_k9vLyiwMVtTatBh2mAARXEAQYASABEgKOvvD_BwE Thank you. Does it work well? Share this post Link to post Share on other sites
Retired Wrencher 6,612 #14 Posted March 6, 2025 16 hours ago, wallfish said: Most of the time it's one of these old school tools. John I am half deaf at my age. Share this post Link to post Share on other sites
Retired Wrencher 6,612 #15 Posted March 6, 2025 12 hours ago, stevasaurus said: The ear does not lie...and it works for adjusting the carb also. In fact, I can do tire presure too. I'm just a walking "Sun" machine. I can tell you which lifter is bad in a car engine, which bearing is good or bad in a transmission, where in the ground the point from a boring machine is, and when a woodpecker is pecking at my T-111 garage siding. I agree with that Steve. After awhile you just hear the sweet spot. I am just thinking of doing this. I have used my ear for many a tractor in the past. Enjoy your day. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,612 #16 Posted March 6, 2025 8 hours ago, oliver2-44 said: Very true Oliver! Share this post Link to post Share on other sites
Retired Wrencher 6,612 #17 Posted March 6, 2025 3 minutes ago, Retired Wrencher said: Very true Oliver! 21 hours ago, OoPEZoO said: I use a free downloaded video tachometer app on my phone. It uses the built in camera flash and adjusts the shutter speed to match the RPM. It works great and its always in my pocket. I will try that today. Thanks for the info. Share this post Link to post Share on other sites
Achto 31,674 #18 Posted March 6, 2025 1 hour ago, Retired Wrencher said: Thank you. Does it work well? I've had pretty good luck with it. Its readings are right in line with the one that our pulling club uses to check us. Share this post Link to post Share on other sites
