6wheeler 661 #1 Posted March 2 Hi all. I need some help on a 1996 John Deere 445 fuel injected tractor. The problem I am having is when I start it. The tractor was in need of a lot of tlc when I got it. It came with many implements and the price was very good. I put a new filter in and found the pickup hose on the pump was cracked. I replaced that and the tractor started. The problem is it runs wide open. I replaced the Map sensor. And the temp sensor. It didn't change anything. I am thinking the fuel pressure regulator may be the culprit as there is a lot of return line pressure. Since the return line goes to a "T" that goes back to the tank and also a line that goes to the pressure drain off valve in the throttle body. If I disconnect the return line from the regulator, It has a lot of pressure coming from the bottom of the regulator from the return. I don't have a book on this machine so I don't know how much pressure there should be. But to me, it seems excessive. I was wondering if is in fact forcing gas into the throttle body through that relief valve. Or, if it even could. I don't want to be shotgunning more parts at it. Especially because I already spent more than I wanted through advice of the JD dealer. He is loving me right now. I first thought of the governor. But, I don't think it has ever been messed with. I checked for vacuum leaks with starting fluid and propane and didn't notice any issues. Honestly? I am stumped. Any help will be greatly appreciated. Pat Share this post Link to post Share on other sites
JCM 10,011 #2 Posted March 2 There are JD guys on here that may have an answer. If that doesn't pan out go on GTT and your question could be answered very quickly . 400 series are well liked. Kawasaki engine ?. @6wheeler Share this post Link to post Share on other sites
6wheeler 661 #3 Posted March 2 Yes 22 hp kawasaki 1 Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,544 #4 Posted March 3 Here is the tech manual for the 4X5 series and the operator's manual for the 445.TM1517_4X5_2_reduce2.pdf JD425_445_OMM144042.pdf TM1517_4X5_2_reduce2.pdf Share this post Link to post Share on other sites
adsm08 2,602 #5 Posted March 3 I'm not a JD guy per se, but I am and EFI guy. High idle speed is rarely if ever caused by too much fuel. Stumbling, smoking, and choking out are caused by too much fuel. High idle/run-away engine RPM is almost always caused by excessive air, be it metered or unmetered. I would start by looking for the throttle plate connected properly to it's control mechanism and operating correctly, then move on to looking for air leaks around the throttle gasket or intake manifold. Issues like you describe are almost always caused by too much air getting into the intake, either through the throttle body, or through a leak somewhere down-stream. On one occasion I saw it caused by a stuck PCV valve. Share this post Link to post Share on other sites
