wallfish 17,232 #26 Posted Friday at 11:08 PM 9 hours ago, ebinmaine said: I'm joining two parts. I have one side that's threaded. And one needs it... Do they need to line up ? Like would welding a rod coupler to the side of the solid rod and thread the other one into it? Or weld the coupler straight on the end? 2 Share this post Link to post Share on other sites
Pete D 254 #27 Posted Saturday at 02:17 AM (edited) On 2/27/2025 at 9:32 AM, ebinmaine said: Cutting oil I have. Tapering the end of the shaft I can do. Drill press or tapping press, not happening. I don't have any way to hold the material straight other than by eye unless somebody has a different suggestion. I'm late to the party. How about a couple of homemade V-Blocks attached to the workbench? EDIT: or even 2x4s with 1" holes in them. You can drill holes through the V-Blocks above the rod, and insert a couple of pins to hold it in place. I'm not sure how you can hold the tap and turn it while keeping that straight... I haven't thought that far ahead! Is this one of those big ratcheting pipe threaders? EDIT: DONT turn the tap. Clamp it in the vice and turn the rod. Edited Saturday at 02:31 AM by Pete D 1 Share this post Link to post Share on other sites
ebinmaine 69,921 #28 Posted Saturday at 01:00 PM 13 hours ago, wallfish said: Do they need to line up ? Not like to micro specs but yes. Really close. 13 hours ago, wallfish said: Like would welding a rod coupler to the side of the solid rod and thread the other one into it? Or weld the coupler straight on the end? I hadn't considered using a straight on connection because of the straight vs threaded rod. The threaded piece is actually a long bolt. I was going to have a threaded portion at both ends so I could attach to existing one and also add a stopper to prevent the plow frame from dropping over snow banks. I certainly could use a bored out piece of 3/4" ID iron pipe as the welded connection. Share this post Link to post Share on other sites
wallfish 17,232 #29 Posted Saturday at 01:20 PM 14 minutes ago, ebinmaine said: I certainly could use a bored out piece of 3/4" ID iron pipe as the welded connection. Maybe cut the bolt and just make it longer with welding on pipe, thick wall tube or the solid rod or even a combination of rod and pipe? I don't completely understand the assignment 1 Share this post Link to post Share on other sites
ebinmaine 69,921 #30 Posted Saturday at 01:24 PM 3 minutes ago, wallfish said: Maybe cut the bolt and just make it longer with welding on pipe, thick wall tube or the solid rod or even a combination of rod and pipe? I don't completely understand the assignment You're headed the right way. I'll get some pics later. Share this post Link to post Share on other sites
JPWH 6,182 #31 Posted Saturday at 02:13 PM 1 hour ago, ebinmaine said: I certainly could use a bored out piece of 3/4" ID iron pipe as the welded connection. I can fix you up with this. 2 Share this post Link to post Share on other sites
