John A 30 #1 Posted February 26 My 2005, GT Classic Garden Tractor Model 73450 needs a cover or a new seat. The factory installed vinyl seat cover has split in several areas but the foam padding has remained in good conditions at this time. I am looking for some suggestions. The ragged seat spoils the looks of my fine Wheel Horse Tractor. Are there quality seat covers available or should I replace the seat and be good for another 15 years or so? Thanks John 1 Share this post Link to post Share on other sites
PWL216 1,134 #2 Posted February 26 @John A I’ll be following the comments with interest. It seems nearly every tractor I acquire needs a new seat for one reason or another. And since I’ve never seen a seat cover that looks good to my eye - I buy new seats for my ‘good’ tractors and use gorilla tape on the others. If I had just one tractor, I would buy a new seat. I just put a new $80 low back seat on a 418-C. It’s ok. Wish I had bought one with a seat back height similar to those on my 314’s. Having said all that, I hope someone knows of good seat covers 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,814 #3 Posted February 26 15 minutes ago, PWL216 said: use gorilla tape on the others. I have used black gorilla tape to very good effect on several seats... works great. Looks great. Very cheap. Just a thought... 2 Share this post Link to post Share on other sites
953 nut 63,003 #4 Posted February 27 @76c12091520h has some very nice aftermarket seats for sale. 1 Share this post Link to post Share on other sites
Red Stallion 154 #5 Posted February 27 I'm in the process of fitting up a new seat I bought of The Bay. Its a bit bigger than stock, but then again, so am I. The bolting pattern didnt match up, so Ive made an adapter plate, which is why I'm still only in the process. 1 Share this post Link to post Share on other sites
John A 30 #6 Posted February 27 Thanks for the comments. I see a lot listed on Amazon but details like mounting patterns are missing. A picture of the bottom with the bolt pattern would be a big help. Assuming there is some heavy gauge metal on the bottom. I am not looking for a major project to simply replace the current seat. Which is an easy task. There are seats available for John Deere models at reasonable prices with satisfied customers. The one I did find (TORO) listed for my model Wheel Horse was over $600 with taxes. Maybe Gorilla tape is the answer at this time. I have wasted many hours over the last few years looking for a reasonably priced replacement. John 1 Share this post Link to post Share on other sites
rjg854 12,624 #7 Posted February 27 21 hours ago, 953 nut said: @76c12091520h has some very nice aftermarket seats for sale. These I believe have the correct mounting pattern. 2 Share this post Link to post Share on other sites
peter lena 9,556 #8 Posted February 27 @John A found this ,https://www.google.com/search?sca_esv=3a00b5f4c73ad6fb&rlz=1C1CHBF_enUS866US866&sxsrf=AHTn8zr9Pzl87niVp7taHc0yU5LplOPjdQ:1740698337486&q=2005+gt+classic+model+73450+tractor+seat+specs&sa=X&ved=2ahUKEwifpsTQ_uSLAxXiKFkFHdmhEAYQ1QJ6BAgnEAE&biw=1024&bih=607&dpr=1 look up seat bolt down pattern , measurements , adapt to those available , pete Share this post Link to post Share on other sites
Red Stallion 154 #9 Posted February 28 2 hours ago, John A said: Thanks for the comments. I see a lot listed on Amazon but details like mounting patterns are missing. A picture of the bottom with the bolt pattern would be a big help. Assuming there is some heavy gauge metal on the bottom. I am not looking for a major project to simply replace the current seat. Which is an easy task. There are seats available for John Deere models at reasonable prices with satisfied customers. The one I did find (TORO) listed for my model Wheel Horse was over $600 with taxes. Maybe Gorilla tape is the answer at this time. I have wasted many hours over the last few years looking for a reasonably priced replacement. John Exactly what happened to me. I triple checked the bolting pattern they provided and it was within a whisker, so I figured I can make that work. Then it turns up with a completely different bolting pattern by several inches. Turned a 20min job into a whole weekend, because I lent out my welder to a mate across town. Share this post Link to post Share on other sites
76c12091520h 4,002 #10 Posted February 28 7" x 7.5" covers most of the early units thru the 90's. Somewhere along the way, 520's and many of later models featured different bolt patterns . 520's typically have a 7.5" x 8" bolt pattern while the other late models have a 8" x 5.75" pattern. 3 1 Share this post Link to post Share on other sites
cafoose 3,520 #11 Posted February 28 @76c12091520h I put one of your seats on my 520-HC and it worked out great 1 Share this post Link to post Share on other sites
CCW 1,454 #12 Posted February 28 I recovered my seat with new material with mixed results. Would I do it again? Maybe. Here is my thread. New seat cover - Wheel Horse Tractors - RedSquare Wheel Horse Forum Share this post Link to post Share on other sites
Red Stallion 154 #13 Posted March 6 Talk seats, has anyone managed to track down replacement coil springs? I can probably make do with what Ive got but it would be nice to replace them. I'm guessing their main job is to compress down and activate the seat switch? Could I swap it out for a slightly compressable eva/rubber block? Share this post Link to post Share on other sites
BlueComet 1 #14 Posted March 14 On 2/28/2025 at 6:54 AM, CCW said: I recovered my seat with new material with mixed results. Would I do it again? Maybe. Here is my thread. New seat cover - Wheel Horse Tractors - RedSquare Wheel Horse Forum Nice job @CCW. Better than I could have done. I have similar situation you did, on my C141, is there someone who will do that kind of work (ship them your old seat, get one with new vinyl back)? Or anyone who has made the vinyl with the horse logo on it? Share this post Link to post Share on other sites
lynnmor 8,254 #15 Posted March 14 1 hour ago, BlueComet said: Nice job @CCW. Better than I could have done. I have similar situation you did, on my C141, is there someone who will do that kind of work (ship them your old seat, get one with new vinyl back)? Or anyone who has made the vinyl with the horse logo on it? Wouldn't that be great! I have contacted a few of the highly recommended seat upholsterers and got nowhere, their attitude is that one should just buy a cheap seat available at the usual stores. It might be an opportunity for someone to start that kind of business but my guess is that sales would be very few due to the high price required. Since Michigan Seat Company (now Milsco) still makes the steel bases perhaps they could be persuaded to do a limited run if there were enough orders prepaid. 1 Share this post Link to post Share on other sites
CCW 1,454 #16 Posted March 17 @BlueComet @lynnmor When I removed the old vinyl cover I kept the WH embossed logo and was planning on gluing it to the new back. The old material is so stiff that I doubt it would stay in place so I passed on applying it. Share this post Link to post Share on other sites
