Pete D 296 #51 Posted Friday at 04:44 PM (edited) Getting back to pulley removal & the bearing splitter, is this available at advance auto? I can't seem to find it. https://shop.advanceautoparts.com/o/loaner-tools?searchTerm=loaner tools&autoSuggest=true&docType=TOP_SEARCH_QUERIES&recentSearch=false Also, no keyways on my pulleys. The nut that was referenced was on the top? What's the point of leaving it on? Thanks! Edited Friday at 04:45 PM by Pete D Share this post Link to post Share on other sites
Lee1977 6,958 #52 Posted Friday at 10:30 PM Your tractor numbering system is off, you should have numbered no. 2, 5 or 6, then you could go back and fill in the missing numbers. 1 1 3 Share this post Link to post Share on other sites
Pete D 296 #53 Posted Saturday at 02:23 AM 3 hours ago, Lee1977 said: Your tractor numbering system is off, you should have numbered no. 2, 5 or 6, then you could go back and fill in the missing numbers. Hey now, I'm a neophyte. I need a little time to learn the correct lingo & techniques! 1 Share this post Link to post Share on other sites
Pete D 296 #54 Posted Saturday at 03:31 PM Well, I ordered a puller kit. Advance doesn't loan them, and harbor freight sells them, but without the parts needed to use it. This only has 3" plates, so I hope it works. I'll know on monday 1 Share this post Link to post Share on other sites
adsm08 2,465 #55 Posted 18 hours ago Which kit did you order? I have a bunch of pullers and bearing splitters, and heating tools. Heat is a good thing-loosener. Share this post Link to post Share on other sites
Pete D 296 #56 Posted 17 hours ago Here's the kit I ordered, now arriving today: https://a.co/d/fXLbVJE I heated one, but was not going to pry on it. They have been saturated with liquid wrench for several days. I expect they will pop right off. Share this post Link to post Share on other sites
adsm08 2,465 #57 Posted 14 hours ago 2 hours ago, Pete D said: Here's the kit I ordered, now arriving today: https://a.co/d/fXLbVJE I heated one, but was not going to pry on it. They have been saturated with liquid wrench for several days. I expect they will pop right off. That's a good kit. I have that one. 1 Share this post Link to post Share on other sites
Pete D 296 #58 Posted 13 hours ago (edited) I'm about to go see if it will work for these pullies. Wish me luck! EDIT: NO LUCK. Too small diameter for the large pulley, too thick to slide under the small ones. Back to the drawing board. Edited 13 hours ago by Pete D Share this post Link to post Share on other sites
adsm08 2,465 #59 Posted 12 hours ago 1 hour ago, Pete D said: I'm about to go see if it will work for these pullies. Wish me luck! EDIT: NO LUCK. Too small diameter for the large pulley, too thick to slide under the small ones. Back to the drawing board. What is the end goal here? Obviously you want to save the pulley, how attached are you to the spindle? I can get anything apart, but I need to know what can and cannot be destroyed to make the plan. Share this post Link to post Share on other sites
Pete D 296 #60 Posted 11 hours ago (edited) Everything is good, so if it can all be saved, that's my goal. If I can't get it apart, on to plan B. EDIT: I think I'm going to have to make my own puller(s) with some plate steel and long bolts. Grrrr. Off to Swopes tomorrow, I guess. Edited 8 hours ago by Pete D Share this post Link to post Share on other sites
