Racinbob
Dino C-121 Part 4
Pullstart
It’s gonna be showroom condition!
ebinmaine
1 hour ago, Racinbob said:
gas tank needed some loving. It cleaned up inside and out really nice
Looks EXCELLENT.
What did you do for that?
What cleaners? Paint? Etc?
Racinbob
25 minutes ago, ebinmaine said:
Looks EXCELLENT.
I just submerged it in hot water and Dawn overnight. Then scrubbed and rinsed well. It really wasn't needed but I then lightly wiped it down with Mothers Back to Black.
  • Excellent 2
peter lena
@Racinbob nice build up ! been using the CARBOLE   MICRO ELECTRIC PUMPS  FOR YEARS , using the low pressure  2-3.5 psi , also added a fuel  check valve  , vertically  just before carb , so I can verify  fuel to carb hold . have set up on 3 horses , been very solid .  might even lay in a 5/16 steel brake line , inside of frame length , as fuel line , dramatically  cutting down on  fuel hose break down , debris . leaving only the short run to tank and carb , easily fitted . MOTHERS BACK TO BLACK ,  very good stuff . always experimenting with a change , for something  , pete
stevasaurus
That looks fantastic Bob!!!  Nice touch with the gas tank.  :occasion-xmas:
