TonyToro Jr. 1,724 #1 Posted February 16 (edited) Just wondering where do you guys get your rear lights for your tractors? I want the lights as close as I can like they were from factory. I got some for my restoration tractor but the lights aren’t wide enough so in need of some places to locate these lights. Edited February 16 by TonyToro Jr. Share this post Link to post Share on other sites
lynnmor 7,495 #2 Posted February 16 Can you find the number on the original? Most auto/truck parts stores can help you with that. Share this post Link to post Share on other sites
TonyToro Jr. 1,724 #3 Posted February 16 I found a number 105202 as the taillight. Does this number work for all the fenders. Just wondering because I switched to metal fenders on this. Share this post Link to post Share on other sites
peter lena 8,984 #4 Posted February 16 @ TONY TORO Jr , been using walmart taillights , no issues , same physical size , also like the led glowing effect , they really have a lot of taillights , pete 1 1 Share this post Link to post Share on other sites
WHX?? 49,953 #5 Posted February 17 All over the jungle most if not all are led tho. If you want to stay original I may be able to scrape up a couple. They should be all universal size. I have seen just the replacement red covers too. 1 Share this post Link to post Share on other sites
TonyToro Jr. 1,724 #6 Posted February 17 10 hours ago, WHX?? said: All over the jungle most if not all are led tho. If you want to stay original I may be able to scrape up a couple. They should be all universal size. I have seen just the replacement red covers too. Yeah I’m trying to stay as original as possible with the tractor. I found the Part number for the lights and we are going to go to Napa today and try and get them. Thanks! 2 Share this post Link to post Share on other sites
cleat 6,868 #7 Posted February 17 For some reason the wheel horse rear fender has extra holes for the tail lights that are not used. Maybe they had other ideas for the lights ? Anyways, even with the correct taillights you will see just a bit of these outer holes out past the lights. 3 1 Share this post Link to post Share on other sites
953 nut 56,814 #8 Posted February 17 I have used these from Tractor Supply, they are as close to factory as I have ever seen. https://www.tractorsupply.com/tsc/product/roadpro-4-in-clearance-marker-light-red Share this post Link to post Share on other sites
cleat 6,868 #9 Posted February 17 7 minutes ago, 953 nut said: I have used these from Tractor Supply, they are as close to factory as I have ever seen. https://www.tractorsupply.com/tsc/product/roadpro-4-in-clearance-marker-light-red Nice, even has the proper electrical connector. 2 Share this post Link to post Share on other sites
JCM 9,931 #10 Posted February 17 (edited) Just curious @953 nut . What model WH 's do you have this type of lens on ? All mine have no indentation in the middle. Edited February 17 by JCM Share this post Link to post Share on other sites
TonyToro Jr. 1,724 #11 Posted February 17 1 hour ago, 953 nut said: I have used these from Tractor Supply, they are as close to factory as I have ever seen. https://www.tractorsupply.com/tsc/product/roadpro-4-in-clearance-marker-light-red Could I see a picture of these lights on your tractor so I can see how they fit? Share this post Link to post Share on other sites
WHX?? 49,953 #12 Posted February 17 (edited) 2 hours ago, cleat said: For some reason the wheel horse rear fender has extra holes for the tail lights that are not used. Maybe they had other ideas for the lights ? Anyways, even with the correct taillights you will see just a bit of these outer holes out past the lights. Very true Cleat 2 hours ago, JCM said: Just curious @953 nut . What model WH 's do you have this type of lens on ? All mine have no indentation in the middle. I have them on a 520 Plunger and they are BRIGHT! Fit as well as originals. https://www.amazon.com/gp/aw/d/B01DGCUQWU/?_encoding=UTF8&pd_rd_plhdr=t&aaxitk=1ade8aca7f78230b86bae4dbdb2dfe44&hsa_cr_id=0&qid=1739803361&sr=1-3-9e67e56a-6f64-441f-a281-df67fc737124&ref_=sbx_be_s_sparkle_lsi4d_asin_2_img&pd_rd_w=BkmSA&content-id=amzn1.sym.8591358d-1345-4efd-9d50-5bd4e69cd942%3Aamzn1.sym.8591358d-1345-4efd-9d50-5bd4e69cd942&pf_rd_p=8591358d-1345-4efd-9d50-5bd4e69cd942&pf_rd_r=JC1M6B74SDPP89FR0V8C&pd_rd_wg=P8fEu&pd_rd_r=05507a3e-6d12-4998-9753-d5e16b6f3b12 Edited February 17 by WHX?? 1 Share this post Link to post Share on other sites
squonk 41,963 #13 Posted February 17 For some stupid reason D.O.T. approved reflectors are made with different mounting hole distance than D.O.T. taillights. The holes won't line up and I still haven't run across one that will 1 1 Share this post Link to post Share on other sites
Handy Don 13,109 #14 Posted February 17 (edited) 1 hour ago, squonk said: For some stupid reason D.O.T. approved reflectors are made with different mounting hole distance than D.O.T. taillights. The holes won't line up and I still haven't run across one that will Smart, I’d say, to prevent stupids from swapping them inappropriately. Edited February 17 by Handy Don Share this post Link to post Share on other sites
953 nut 56,814 #15 Posted February 18 11 hours ago, JCM said: Just curious @953 nut . What model WH 's do you have this type of lens on ? All mine have no indentation in the middle. I have a pair on the GT-14 and a pair on the 418-C. The base is a prefect fit and if anyone is bent over being critical of the indentation in the lens they may get a boot in the but. 2 Share this post Link to post Share on other sites
Brockport Bill 1,786 #16 Posted February 18 not sure what model tractor you have but partstree.com has lens -- not the light itself Share this post Link to post Share on other sites
TonyToro Jr. 1,724 #17 Posted February 18 11 hours ago, Brockport Bill said: not sure what model tractor you have but partstree.com has lens -- not the light itself Thanks but I need the whole assembly 1 Share this post Link to post Share on other sites
RED-Z06 2,415 #18 Posted yesterday at 03:26 AM I put the above mention 2 bulb style on my 416-H a couple years ago, i put red LEDs in both pods on each one and it fits perfectly in the stock intentions, the nice part is they actually put out good light. The dark backing doesn't look as cheap/weathered as white does. 2 Share this post Link to post Share on other sites
