Treepep
C100
Treepep
Are heard and gasket available for the ten horse Kohler?  Found a nice old C100 spark threads are effed.
ebinmaine
Absolutely.
Redsquare has several vendors that could have a good used head.
Gaskets as well.
Treepep
I hoped...same business for a number of motors I think. .used and plane I think would be fine.  New gasket.  Torque. Run re torque. .thank you sir
ebinmaine
That's exactly it.
:handgestures-thumbupright:
WHX??
I Save has new ones and used all over fleabay ... use a gasket that has a fire ring.
oliver2-44
You can easily repair the spark plug threads in the head with a helicoil.
Treepep
YOU can easily do that.  I would need an adult:D
  • Haha 1
Treepep
Also need the head bolts.  Familiar with T sequence.  I imagine Lincoln has some used..
ebinmaine
Head bolts are a standard grade 8 with the correct extra thick washers. You just need to know the right sizes.
ebinmaine
I would actually say, unless you know for absolute sure how old the head bolts are, always replace them. Do not put in used head bolts.
Treepep
Heard.  I would say new as well.  Although one could argue the old metal is probably better.  even having been stretched and heated already.
ebinmaine
To some extent and depending on certain parts, I would agree.
I no longer buy any nuts bolts or most other Hardware from any box stores or TSC or amazon.
I've been buying nearly all of my Hardware from Bolt Depot in massachusetts.
I can't say for sure that it is USA made. It is definitely a superior quality though. Pricing is excellent. Service is excellent.
ebinmaine
@Treepep
If you get me the sizes and quantities of the bolts and washers I'll send them to you for whatever they cost plus shipping. I buy in bulk.
oliver2-44
Never to young or old to learn with the excellent help here.
Treepep
21 hours ago, ebinmaine said:
@Treepep
Heard.  Thank you sir
Treepep
I agree wholeheartedly on many fronts.  I do a lot to challenge my mind and body on the daily.  Im better at learning new business by doing or being shown.  NOT U tub or facebag.  Never drilled and tapped a head.
Dad is around thankfully, and does not care about wrenching anymore. Retired M/E engineer
I know no other humans that have that sort of knowledge.  Well near me.  Currently talking (actually literally speaking) to another human about a trade for a C120 auto or project C100.  we will hammer it out.  just details. I do enjoy the square.  wish I could download some member/experience.:)
ebinmaine
I started with Wheelhorses back in late '16 early '17 having almost no knowledge whatsoever. Since then our Herd and our knowledge has grown exponentially. As will yours.
