953 nut 56,884 #76 Posted Friday at 01:17 AM My guess is the engine was a Friday quitt'n time unit and they threw in two intake valves. Exhaust valves are thicker and though the intake valve used as exhaust will seat adequately when cold it could warp a slight bit when hot. Buy a new exhaust valve, buy a valve spring compressor, clean it up real well and return it when you are finished. Retail auto parts stores do it all the time. 2 Share this post Link to post Share on other sites
Racinbob 11,536 #77 Posted Friday at 02:06 AM 38 minutes ago, 953 nut said: My guess is the engine was a Friday quitt'n time unit and they threw in two intake valves. Exhaust valves are thicker and though the intake valve used as exhaust will seat adequately when cold it could warp a slight bit when hot. Buy a new exhaust valve, buy a valve spring compressor, clean it up real well and return it when you are finished. Retail auto parts stores do it all the time. I've pretty much ruled out it being a valve issue. The exhaust valve is thicker and just don't see the smaller valve spec'd for the 14 even coming close to working. One of my first thoughts was that a 16hp block slipped in there but the head bolt count said no to that. I never checked the dims on the od of the valve seat though. I'm no engine guru but I'm still saying the coil. If the issue still persists after I get through my list I'll just get the tools. The compressor, leak down tester, etc. 1 Share this post Link to post Share on other sites
johnnymag3 2,559 #78 Posted Friday at 04:03 PM My ..... The part you mentioned when taking the seat is this - "I used the CHOKE to keep it running" ....is throwing me a curveball..... A failing coil doesn't care if you are choking the carb to get fuel. Another curveball is ...why would the Valve care if you are CHOKING the engine??? Isn't that a mechanical type issue ?? My money is on COIL ,but I'm still confused how using the choke is keeping it running if the COIL is on its way out..... I will be following to know the end result.... 1 Share this post Link to post Share on other sites
squonk 42,005 #79 Posted Friday at 04:41 PM 37 minutes ago, johnnymag3 said: My ..... The part you mentioned when taking the seat is this - "I used the CHOKE to keep it running" ....is throwing me a curveball..... A failing coil doesn't care if you are choking the carb to get fuel. Another curveball is ...why would the Valve care if you are CHOKING the engine??? Isn't that a mechanical type issue ?? My money is on COIL ,but I'm still confused how using the choke is keeping it running if the COIL is on its way out..... I will be following to know the end result.... A rich mixture is easier to fire than a lean one. Weak spark will need more fuel to fire. 3 Share this post Link to post Share on other sites
Racinbob 11,536 #80 Posted Friday at 04:51 PM @johnnymag3I think Mike nailed it. It was similar to running out of fuel but different. I ordered the new coil from Kentucky and it made it to Indy quickly.....................9 days ago. Another non-related package was being held hostage too but it was released 2 days ago the usual trip to South Bend and then here today. I'll have to talk to my negotiator about that. I'd rather they would have released the coil. Moving Through Network In Transit to Next Facility, Arriving Late February 23, 2025 Arrived at USPS Regional Destination Facility INDIANAPOLIS IN DISTRIBUTION CENTER February 19, 2025, 3:26 pm 1 3 Share this post Link to post Share on other sites
Racinbob 11,536 #81 Posted Saturday at 07:31 PM They released one captive and I received it but now they have another one apparently to keep the coil company. @WHX?? Guess where the Wisconsin package is sitting. 2 Share this post Link to post Share on other sites
Pete D 253 #82 Posted Saturday at 11:28 PM 3 hours ago, Racinbob said: They released one captive and I received it but now they have another one apparently to keep the coil company. @WHX?? Guess where the Wisconsin package is sitting. California? USPS sometimes ships my packages from the East coast to CA before delivering it to me in Pennsylvania. Share this post Link to post Share on other sites
David Blanchard 14 #83 Posted yesterday at 02:17 AM While the head is off would not hurt to pop the valves out & lap them any way. Anyone you know may own the proper tools you could borrow? Those tools are not real expensive but understand not wanting to invest in something not likley to be used again. Still betting its a coil issue. Share this post Link to post Share on other sites
Pete D 253 #84 Posted yesterday at 02:40 AM 21 minutes ago, David Blanchard said: Those tools are not real expensive but understand not wanting to invest in something not likely to be used again. One (two?) drinks at a bar / restaurant buys them. Share this post Link to post Share on other sites
David Blanchard 14 #85 Posted yesterday at 02:52 AM Yes still needing some lapping compound & a spring compressor makes it much easier but amazon/ ebay makes the stuff easy to obtain. I still miss the local neighborhood parts stores with machine shops we grew up with Share this post Link to post Share on other sites
Racinbob 11,536 #86 Posted yesterday at 10:54 AM 11 hours ago, Pete D said: California? USPS sometimes ships my packages from the East coast to CA before delivering it to me in Pennsylvania. No Pete. This isn't a routing issue. Apparently the Indy branch is making some changes causing packages to sit, sometimes for weeks. Guys, it's not a matter of buying the tools. I just don't like buying something to use once and sit in the drawer forever. Countless times I was tempted to tool up for rebuilding these engines but I just never did. I've check out the valves and I'm pretty certain they are fine. I'm sticking to doing my list as I posted in post #21. If it still has the problem then I'll take it further. On the other hand, if I had the tools I would think about attacking a K-341 that's sitting on the shelf. Rebuilt 57 hours ago but what I believe IS a valve issue occurred. I was just going to get it to someone who wanted to tinker with it but...................... That's another story. 1 Share this post Link to post Share on other sites
ebinmaine 69,921 #87 Posted yesterday at 10:57 AM 2 minutes ago, Racinbob said: . I was just going to get it to someone who wanted to tinker with it but...................... That's another story I'd be happy to own and tinker with that but the commuting distance could be prohibitive. 1 Share this post Link to post Share on other sites
Racinbob 11,536 #88 Posted yesterday at 11:00 AM With this bunch of yahoos stranger things have happened Eric. 1 1 Share this post Link to post Share on other sites
ebinmaine 69,921 #89 Posted yesterday at 11:01 AM 1 minute ago, Racinbob said: With this bunch of yahoos stranger things have happened Eric. T'is true! 1 Share this post Link to post Share on other sites
Lagersolut 717 #90 Posted yesterday at 06:21 PM 7 hours ago, Racinbob said: No Pete. This isn't a routing issue. Apparently the Indy branch is making some changes causing packages to sit, sometimes for weeks. Guys, it's not a matter of buying the tools. I just don't like buying something to use once and sit in the drawer forever. Countless times I was tempted to tool up for rebuilding these engines but I just never did. I've check out the valves and I'm pretty certain they are fine. I'm sticking to doing my list as I posted in post #21. If it still has the problem then I'll take it further. On the other hand, if I had the tools I would think about attacking a K-341 that's sitting on the shelf. Rebuilt 57 hours ago but what I believe IS a valve issue occurred. I was just going to get it to someone who wanted to tinker with it but...................... That's another story. I'm sharing your frustration with this magneto held hostage - I want to know what this ghost is and the tractor fixed - check this thread every day hoping we all have our answer 1 Share this post Link to post Share on other sites
Racinbob 11,536 #91 Posted 6 hours ago I don't know how you guys would handle this. I know it's not the sellers fault. He was lightning quick to get it shipped. He apparently saw the delay a few days ago and sent me a message about it asking for my patience. I assured him that I understand. Yesterday I was in a 'mood'. @WHX?? the Wisconsin package was pardoned and released to go to South Bend. It probably will get here today, tomorrow at the latest. I sent the seller another message saying I was another one shipped or a refund NOW. He came back saying he'd ship another one asap. Then I felt a little bad. Again, it wasn't his fault. After thinking about it I wrote him back saying to get another one shipped and if I do end up with two I'll ship the other one back on my nickel. This was printed out this morning. Apparently the updates have stopped. Moving Through Network In Transit to Next Facility, Arriving Late February 23, 2025 Arrived at USPS Regional Destination Facility INDIANAPOLIS IN DISTRIBUTION CENTER February 19, 2025, 3:26 pm Arrived at USPS Regional Origin Facility LEXINGTON KY DISTRIBUTION CENTER February 18, 2025, 8:28 pm Accepted at USPS Origin Facility HEBRON, KY 41048 February 18, 2025, 7:13 pm Departed Shipping Partner Facility, USPS Awaiting Item HEBRON, KY 41048 February 17, 2025, 6:31 pm Shipping Partner: WINIT Shipping Label Created, USPS Awaiting Item HEBRON, KY 41048 February 16, 2025, 8:30 pm Share this post Link to post Share on other sites
squonk 42,005 #92 Posted 5 hours ago Sometimes I wonder if it's more related to small packages getting "lost or delayed" My wife bought some seeds for her garden from Gurneys. 2 small envelopes and it took 14 days to arrive after they were shipped. I just sent a good size box to SC. Priority 3 day shipping and it got there in 2 days. I ordered some stuff from McMaster Carr Fri. afternoon. I got it the next day (Sat). Order said it was expected to arrive today (Mon). Share this post Link to post Share on other sites
Racinbob 11,536 #93 Posted 2 hours ago 3 hours ago, squonk said: Sometimes I wonder if it's more related to small packages getting "lost or delayed" My wife bought some seeds for her garden from Gurneys. 2 small envelopes and it took 14 days to arrive after they were shipped. I just sent a good size box to SC. Priority 3 day shipping and it got there in 2 days. I ordered some stuff from McMaster Carr Fri. afternoon. I got it the next day (Sat). Order said it was expected to arrive today (Mon). Not in this case Mike. We track a lot of stuff and know that if it hits the Indy branch it's a crapshoot. You can do a search on it and know what I mean. They are claiming that changes are being made and they are 'on top of it'. This is the first time we've experienced a delay like this but many are seeing weeks go by. There's even the potential of legal action being taken. Good luck with that. Fortunately the package from Jim made it today but we figured it would. We saw that it was heading to South Bend and that means we'll get it the next day or in two days if it arrived in SB late in the day. Share this post Link to post Share on other sites
