Pullstart
Waste Oil Burner
Pullstart
Come to think of airflow, I am not sure if I make the holes larger if I’ll get the volume I need or if the bigger blower will create increased pressure to make the fire happy.
Ed Kennell
It's probably a fine line  between   sufficient air to create an efficient combustion vs maintaining a negative pressure in the exhaust flue pipe to insure no gas escapes.
I have seen outside exhaust fans to insure safe gas removal.        Just thinking SAFETY
  • Excellent 3
Pullstart
It did take a bit to get the flue hot.  Once it was though, draft was not an issue.  Also, my shop is not very tight.  Plenty of fresh air available for combustion and draft.
I also played with baffles in the horizontal flue pipe.  It did not pay off and I saw smoke seep from the pipe joints.  I removed them right away and have no intention to place them back in any time soon.
I’LL ALSO MENTION, the doors of the shop were open during operation, to allow the smoke to clear, to allow some failure and insure my safety.  It still got a bit hazy in there.  I made sure to keep myself in fresh air (door openings or outside) while not tinkering with the setup.
  • Excellent 2
Pullstart
I also took a moment to RTV Red (650 degrees) the gaps in the exhaust pipe.  I might even hit them with some high temp pellet stove tape.
Pullstart
  • Excellent 3
Pullstart
  • Excellent 2
Pullstart
I’ve been playing with this thing, and think the blower just can’t overcome the vent length.  It’s a thing, and I knew it might be.  I don’t want a fan on the exhaust pulling, for the concern it might get sooted up.  I think I need to pull a length of pipe out of the system, though I don’t want to.  That’s a cost of trial and error.
Other than the masses of people telling me I need this, watching this quick video of the burner working outside reminds me how good it was with vent out of the playing field.
Pullstart
Shortening the horizontal flue helped increase temps greatly!  I’m not sold on the whole design, but it’s getting better.
Pullstart
I just shut it down.  Once the fire was out, my rotor stack was close to 950 degrees without fire.
  • Excellent 3
ri702bill
Time for the Marshmallows!!
  • Haha 1
adsm08
Well, I do love saying "I told you so".
  • Haha 3
Pullstart
I didn’t doubt you, but needed proof.  It looks good where it’s at :handgestures-thumbupright:
ri702bill
Some may call it " Trial & Error" Designing, but to a retired Engineer, that's just good old data collection & validation !! :handgestures-thumbupright:
Rube Goldberg would be right proud of you Kevin. :rolleyes:
Edited by ri702bill
Pullstart
Makes sense to me!
  • Haha 5
Ed Kennell
No mistakes in trial and error or research and development.    Just one step closer to success.
  • Excellent 2
ri702bill
Failure is what motivates one to success.
kpinnc
...Clearly I haven't put up enough pictures of my own adventures in fabrication. :rolleyes:
  • Haha 2
Pullstart
Pullstart
Pullstart
I’m starting to get somewhere!
  • Excellent 2
Blasterdad
Nice! You'll have those plastic wheels melted off there in no time! :handgestures-thumbupright: :lol:
  • Haha 3
Pullstart
They started blistering the other day.  I finally had to take them off.  :sad-pacing:
  • Sad 1
  • Heart 1
Pullstart
I finally achieved a good hot burn!  It was fun to ramp this up to the point of making the entire burner system glow.
  • Excellent 6
wallfish
Nice! That thing is cranking out the heat.
Interesting with the oil drip feed over the top as a preheat system. Does it not burn as good or clean with the oil feeding directly into the bottom reservoir area?
The only reason I ask is because it seems like the partial burn/heat of it on the way down would or might cause some more soot or smoke because it's not as clean or thorough of a burn in that area on the way down.
