clueless 3,331 #1 Posted February 11 I have an angle grinder and a reciprocating saw, no torch, which would you use to cut the rod or other suggestions? Share this post Link to post Share on other sites
ri702bill 10,571 #2 Posted February 11 What madel tractor?? IF the lower gear is pinned in place, like a 702, just remove the pin & gear. Later models have the gear welded on. Planning to replace the shaft?? Share this post Link to post Share on other sites
squonk 44,860 #3 Posted February 11 Recip saw would be the go to if the shaft was still in the tractor. 3 Share this post Link to post Share on other sites
953 nut 63,003 #4 Posted February 12 6 hours ago, clueless said: I have an angle grinder and a reciprocating saw, no torch, which would you use to cut the rod or other suggestions? You aren't cutting up that nice RJ-35 are you? 1 Share this post Link to post Share on other sites
adsm08 3,864 #5 Posted February 12 That saw will take hours, and probably more than one blade, to get through that shaft. I vote grinder. 1 Share this post Link to post Share on other sites
oliver2-44 11,062 #6 Posted February 12 (edited) Sometime the weld on the lower gear is marginal and it can be ground off. Edited February 12 by oliver2-44 1 Share this post Link to post Share on other sites
RED-Z06 2,690 #7 Posted February 12 Recip with a good blade, go right through 1 1 Share this post Link to post Share on other sites
C-85 778 #8 Posted February 12 Cut the steering wheel, save the shaft? C-85 Share this post Link to post Share on other sites
123Go 1 #9 Posted February 20 Last one I had the pin deform bad & wouldn't come out I got a cobalt bit & drilled it out. Then beat the wheel up/off with a sledge & small iron pipe working around its hub. I had another yrs before where I cut the wheel off with my Sawzall (cut hub up in 3-4 pieces) but I saved the shaft. Lenox fine or medium tooth saw blade most likely fwiw? The cobalt bit was quicker/easier, it drilled through it like butter, sorry I don't recall the bit size/brand? Same size or a hair smaller than my pin dia not to drill the shaft itself out surely? That was my 300 & 400 series tractors. 1 Share this post Link to post Share on other sites
