Knight Rider 1 #1 Posted February 11 (edited) Sorry for the long read…So I bought a 98’ 314/8 over the weekend, when I picked it up I noticed that the motor was really loose. So I brought it home and found that it is missing 2 motor mount bolts and the two that are there a barely holding on. So I decided to take the motor out that way it would be easier to bolt on the plates to the motor then to the frame. Checked to make sure the threads weren’t buggered up and they weren’t. Since I got the motor out I decided to tear it down to the bare frame to clean it up since it was pretty filthy, when I did that I noticed there were two bolts missing from the transaxle that bolts it to the frame. Both top and bottom bolts on the right side were missing. My question is would there be gear oil coming out that top hole of the transaxle? Because I got gear oil all over that transaxle! I’m hoping when I bolt the transaxle back to the frame that it will fix the gear oil that’s coming from somewhere. There is no gear oil on the top of the transaxle just right were it bolts up and the bottom. Thanks for any help Edited February 11 by Knight Rider Share this post Link to post Share on other sites
kpinnc 13,703 #2 Posted February 11 (edited) The holes on the 8 speed are tapped all the way through, so missing either will leak gear oil. Typically due to the oil level only the bottom two will leak. The right side motor mount bolts ( if sitting on the tractor) are installed from the bottom. That side of the oil pan is threaded all the way through where the engine bolts to the pan. The left two bolts go in the standard tabs. Edited February 11 by kpinnc 2 Share this post Link to post Share on other sites
Knight Rider 1 #3 Posted February 11 (edited) So what do you put on the bolt when you put it back in the transmission to keep it from leaking? And what would have happened if I didn’t notice the two right side motor mount bolts missing? Edited February 11 by Knight Rider Added another question Share this post Link to post Share on other sites
kpinnc 13,703 #4 Posted February 11 17 minutes ago, Knight Rider said: So what do you put on the bolt when you put it back in the transmission to keep it from leaking? And what would have happened if I didn’t notice the two right side motor mount bolts missing? Nothing. When the bolts are tight, they don't leak. At least none of mine do at those bolt holes. 2 Share this post Link to post Share on other sites
Knight Rider 1 #5 Posted February 11 1 minute ago, kpinnc said: Nothing. When the bolts are tight, they don't leak. At least none of mine do at those bolt holes. Thank you 1 Share this post Link to post Share on other sites
Wild Bill 633 866 #6 Posted February 11 (edited) You could use Permatex Form-A-Gasket No.2 Sealant or equivalent. It is used on automotive engine head bolts where the tapped holes go into the water jacket. Or red Locktite red. I replace the bolts with set screws with red Locktite and distorted thread flange nuts, all grade 8. Edited February 11 by Wild Bill 633 1 Share this post Link to post Share on other sites
Handy Don 13,340 #7 Posted February 11 1 hour ago, Wild Bill 633 said: You could use Permatex Form-A-Gasket No.2 Sealant or equivalent. It is used on automotive engine head bolts where the tapped holes go into the water jacket. Or red Locktite red. I replace the bolts with set screws with red Locktite and distorted thread flange nuts, all grade 8. Being mindful not to let any excess sealant get inside the transaxle. Share this post Link to post Share on other sites
Knight Rider 1 #8 Posted February 11 (edited) I wonder what the torque spec is on the motor mount and transmission mount bolts? Edited February 11 by Knight Rider Share this post Link to post Share on other sites
pfrederi 18,322 #9 Posted February 11 3 hours ago, Knight Rider said: I wonder what the torque spec is on the motor mount and transmission mount bolts? No special torque specified use these 3 1 Share this post Link to post Share on other sites
