turbofn1 6 #1 Posted February 5 More of a weekend warrior mechanic here , 40 year Aircraft Mechanic that loves to rebuild most anything, Right now currently own 3 wheel horse tractors, c160 with Kwik Way plow / c140 with mower deck ,and what I believe is a c161 16hp hydrostatic drive all run and start normal after cleaning up and chasing some wires also have a complete unattached kwikway loader for older wheel horse that needs reassembled with the 4 new hydraulic cylinder I purchased for it , it's the same loader I have on the C160. But what I'm really interested in is a 3 point hitch setup for use with a cultivator or disc plow setup , would be ideal to find a model number , diagrams or pictures of 3 point hitch set up for one of these tractors, 1 Share this post Link to post Share on other sites
HyperPete 459 #2 Posted February 5 (edited) Hi, I live near Dillsburg and saw a couple of small 3-point hitches (red) on Facebook Marketplace. Have you looked there? There is a bunch of WH stuff listed. BTW, welcome! EDIT: I re-read your post and realize you are looking for documentation. Sorry. If you search by your model number, you can limit your search to the files section. That may give you your desired results. Edited February 5 by Pete D Share this post Link to post Share on other sites
turbofn1 6 #3 Posted February 5 I seen one for I believe $295 but owner stated it was for a gt14 and since being new to wheel horse tractors Im not sure if it would cross over to any of mine and he did not know either, that's some of the help I could use , there seems to be a company a-z with an aftermarket 3 point hitch assembly but I'm having a hard time justify $500 1 Share this post Link to post Share on other sites
turbofn1 6 #4 Posted February 5 By the way. Nice to meet you Pete 1 Share this post Link to post Share on other sites
oliver2-44 10,339 #5 Posted February 5 (edited) There was not a WH 3 point made to fit any of you tractors. Only the. gT14 and D series has 3 point hitches available. There are some threads on here where people have made their own. I’ve also seen the Sears/craftsman 3 poin hitches retrofitted to. WH tractors. But be advised the Sears 3 point hitch has different dimensions and only works with Sears implements. Edited February 5 by oliver2-44 4 Share this post Link to post Share on other sites
WHX?? 50,629 #6 Posted February 5 38 minutes ago, oliver2-44 said: There was not a WH 3 point made to fit any of you tractors. Only the. gT14 and D series has 3 point hitches available Optional on a Super C-195 too JIm 3 1 Share this post Link to post Share on other sites
Ed Kennell 40,410 #7 Posted February 5 to the As Jim stated, the Super C-195 was the only C series that was designed for a factory 3 point. Yours will have to be a custom built hitch. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,235 #11 Posted February 5 The limiting factor is the 23" tall tires. The tractor is too close to the ground to make the lift effective when raised. Sears has the same problem. Wheel Horse tiller lift requires it be repositioned for transport so the tines clear the ground. Have a Sears self-powered tiller with Sears 3-point on a C-120. Got around the problem by adding a cable between the tiller and tractor that applies the belt driven tiller clutch when the tiller is lowered. Tiller raised and the tines are disengaged and spin freely to clear the ground. No more yard torn up at the end of the tilled rows. 3 Share this post Link to post Share on other sites
turbofn1 6 #13 Posted February 6 Thanks for all the replies , I'm having the feeling that I'll use 2 wheels horses for the Front loaders , 1 wheel horse with mower deck and Either Jd317 or the jd316 I have for a plow setup, my goal was to have one universal tractor but may not be that practical at the moment, 2 Share this post Link to post Share on other sites
ebinmaine 70,580 #14 Posted February 6 18 minutes ago, turbofn1 said: one universal tractor My Other Half and I have found over the years that having several available is a more efficient way to operate. 1 Share this post Link to post Share on other sites
Easton Rich 466 #15 Posted February 6 Welcome! Thank you for your service! I hope you find what you need on here while getting to know a few of us. Share this post Link to post Share on other sites
Alrashid2 382 #16 Posted February 10 You're not too far from me, I'm over in Quakertown. Welcome brother! 2 Share this post Link to post Share on other sites
953 nut 57,766 #17 Posted February 10 @kpinnc has a nice three point on a smaller and may be able to hook you up with information on it. As @gwest_ca mentioned the 23" tall tires would be a limiting factor on adding a three point hitch. I built one for a 953 that is quite simple and more for show than it is for work. Jay @JPWH also built one that is more heavy duty that you may want to look at. Share this post Link to post Share on other sites
HyperPete 459 #18 Posted February 11 I don't know if this might be useful as a starting point, but the price is right. Located in Hershey. https://www.facebook.com/share/18FJ3SBJNs/?mibextid=kL3p88 1 Share this post Link to post Share on other sites
kpinnc 13,663 #19 Posted February 11 13 hours ago, 953 nut said: @kpinnc has a nice three point on a smaller and may be able to hook you up with information on it A 3 point on a small tractor is nice, but you can very easily exceed what the tractor can do with a CAT-0 implement. Don't get me wrong, a Wheel Horse is a stout machine. My grandpa would describe it as "willing mind, but not enough behind" situation. You can design in some help with your lift to raise the back of any implement higher so you clear the ground. I just made my top link roll forward as the implement is lifted for that reason. Of course any hitch add involves alot of fabrication. Mine basically adapts a D series hitch to my Bronco. It works well, but it's alot of modification. 1 3 1 Share this post Link to post Share on other sites
