stvski80085 42 #1 Posted February 4 Hello again, I am trying to find the manual for my mower. It's a right hand discharge 36 inch mower. The tensioning pulley is bad. Can't replace the bearing on this one so it looks like it's one unit. Second question, I guess there is no grease fitting on the main bearings. Not sure what the name of the 3 main shaft's are. Do you have to take them apart to grease them up. I'm pulling the whole thing apart to clean and paint the deck so if I do no big deal. I think I could drill and tap a grease fitting into each of those unless that's a bad idea. Steve Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,168 #2 Posted February 4 Here is a list of all of them to help you identify what you have. Mower DNA 1971 model 5-0710 replaced by 1971 model 5-0711 1972 model 5-0720 1973-1974 model 5-0721 1975 model 5-0722 1976 model 65-36MS01 1977 model 75-36MS01 1977 model 75-36MS02 1978 model 85-36MS01 1979 model 95-36MS00 - These decks use blades with 5/8" x 3/4" center hole unless the spindle has been upgraded ----------------------------------------------------------------------------------------------------------------------------------------------------------- 1979 model 95-36MS01 replaced by 1980-1982 model 05-36MS01 - Last year for bearings with 3/4" ID 1983-1984 model 05-36MS02 - First year for bearings with 17mm ID unless older spindles were updated. These decks use blades with a 3/4" center hole Note - 17mm is .669" Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,168 #3 Posted February 4 If you search our files using a model number as written above and look at ones with IPL in the title there is a breakdown of the different spindle assemblies used on that deck. The first one is the original. An example. Click on the fuzzy picture in the link below and click the thumbnails to enlarge. Share this post Link to post Share on other sites
stvski80085 42 #4 Posted Tuesday at 01:50 AM That’s the one. The part is number 25 in the pick. Looking for a part number. Share this post Link to post Share on other sites
stvski80085 42 #5 Posted Tuesday at 01:53 AM I see. Had to scroll down to download it. Thanks again. Share this post Link to post Share on other sites
