1968Commando 26 #1 Posted yesterday at 12:19 PM Hello, I am restoring my great uncles 1968 wheel horse commando and I am using a die grinder with a sanding wheel on it and it has just been taking for ever. I am using a 120 grit flap wheel on a grinder to help with getting the rusty areas ground down. The part of the issue is definitely the compressor available to me cannot keep up with the air needed to run the die grinder unfortunately me being 16 and trying to do this project under 500 bucks I’m not sure what I could do to speed the process up if there even is any way to speed it up just let me know thank you. 4 Share this post Link to post Share on other sites
953 nut 56,450 #2 Posted yesterday at 12:47 PM It is nice to see a young new member keeping a Wheel Horse in the family. I know you wouldn't want to spend a third of your budget on one tool but the surface conditioning tool in the link below would make the job much quicker. Citrus based paint removers are relatively safe to work with and do a good job of removing paint. Before you use any chemicals please go over the safety instructions and have your parents go over them with you. Please ask any questions that may come up as you go along, we are here to help. https://www.harborfreight.com/9-amp-surface-conditioning-tool-58079.html?utm_source=google&utm_medium=cpc&utm_campaign=21894824535&campaignid=21894824535&utm_content=171327958738&adsetid=171327958738&product=58079&store=3234&gad_source=1&gclid=CjwKCAiA74G9BhAEEiwA8kNfpcR9eGpDQfniunOw_PlpivxbHvBgGxoYVzL_tJJjdq0FBgIZ22PjKxoCxGEQAvD_BwE 2 Share this post Link to post Share on other sites
1968Commando 26 #3 Posted yesterday at 12:52 PM (edited) 5 minutes ago, 953 nut said: It is nice to see a young new member keeping a Wheel Horse in the family. I know you wouldn't want to spend a third of your budget on one tool but the surface conditioning tool in the link below would make the job much quicker. Citrus based paint removers are relatively safe to work with and do a good job of removing paint. Before you use any chemicals please go over the safety instructions and have your parents go over them with you. Please ask any questions that may come up as you go along, we are here to help. https://www.harborfreight.com/9-amp-surface-conditioning-tool-58079.html?utm_source=google&utm_medium=cpc&utm_campaign=21894824535&campaignid=21894824535&utm_content=171327958738&adsetid=171327958738&product=58079&store=3234&gad_source=1&gclid=CjwKCAiA74G9BhAEEiwA8kNfpcR9eGpDQfniunOw_PlpivxbHvBgGxoYVzL_tJJjdq0FBgIZ22PjKxoCxGEQAvD_BwE I will look into this although it may be a last resort due to my budget with the chemical strippers I just put it on the paint and then the paint scrapes off correct or is there more to that? Edited yesterday at 12:52 PM by 1968Commando Spelling Share this post Link to post Share on other sites
953 nut 56,450 #4 Posted yesterday at 01:14 PM 14 minutes ago, 1968Commando said: with the chemical strippers I just put it on the paint and then the paint scrapes off correct or is there more to that? As I said, go over the instructions with your parents. I was a teenager and know it isn't cool to ask your parents but we want you to be safe and have this be remembered as a good learning experience. With old paint that has a bit of rust imbedded in it a second coating of stripper using a Scotch-Brite pad or wire brush may be needed. Be safe at all times, good rubber gloves, face and eye protection and good ventilation of the work area are a must. 3 Share this post Link to post Share on other sites
Achto 28,082 #5 Posted yesterday at 01:18 PM (edited) If you are on a low budget, maybe an E-tank would be the way to go. They are cheap to make, no expensive chemicals. Edited yesterday at 01:56 PM by Achto 4 1 1 Share this post Link to post Share on other sites
oliver2-44 10,016 #6 Posted yesterday at 01:24 PM I’ll also recommend an E-tank. That’s how I did my first tractor Share this post Link to post Share on other sites
1968Commando 26 #7 Posted yesterday at 01:39 PM 13 minutes ago, oliver2-44 said: I’ll also recommend an E-tank. That’s how I did my first tractor Now e tank is electricity and you need a battery charger would a low amp battery tender work or no? Share this post Link to post Share on other sites
1968Commando 26 #8 Posted yesterday at 01:39 PM (edited) 25 minutes ago, 953 nut said: As I said, go over the instructions with your parents. I was a teenager and know it isn't cool to ask your parents but we want you to be safe and have this be remembered as a good learning experience. With old paint that has a bit of rust imbedded in it a second coating of stripper using a Scotch-Brite pad or wire brush may be needed. Be safe at all times, good rubber gloves, face and eye protection and good ventilation of the work area are a must. Thanks sir I will definitely look into this I actually think we have some paint stripper at the house will talk to parents before I use for sure I also probably need to start wearing a mask when sanding Edited yesterday at 01:41 PM by 1968Commando 1 1 Share this post Link to post Share on other sites
1968Commando 26 #9 Posted yesterday at 02:04 PM Would there be any downsides to using a cup brush and a grinder for getting the old paint off I do have a cup brush and a grinder already Share this post Link to post Share on other sites
SylvanLakeWH 26,358 #10 Posted yesterday at 02:07 PM 24 minutes ago, 1968Commando said: for sure I also probably need to start wearing a mask when sanding Yes definitely... And not a cheapo flat mask... at least a N-95... I also set up a fan next to the work so most blows away from me and the works area... I always do it outside... 1 Share this post Link to post Share on other sites
JimSraj 460 #11 Posted yesterday at 02:27 PM (edited) 49 minutes ago, 1968Commando said: Now e tank is electricity and you need a battery charger would a low amp battery tender work or no? Whatever charger you use has to be a manual type so it continues to provide current. Edited yesterday at 02:28 PM by JimSraj Misspelling 2 Share this post Link to post Share on other sites
1968Commando 26 #12 Posted yesterday at 02:46 PM 18 minutes ago, JimSraj said: Whatever charger you use has to be a manual type so it continues to provide current. Unfortunately my charger is one were you plug it in and it automatically starts charging so I believe a E tank is out of the question 1 Share this post Link to post Share on other sites
Racinbob 11,393 #13 Posted yesterday at 03:02 PM 12 minutes ago, 1968Commando said: Unfortunately my charger is one were you plug it in and it automatically starts charging so I believe a E tank is out of the question As long as you parallel connect a battery in the circuit it will work. I also agree with an e-tank. I'm sure somebody will tell you it won't strip paint but......it does. Share this post Link to post Share on other sites
WHX?? 49,645 #14 Posted yesterday at 03:03 PM (edited) 2 hours ago, 1968Commando said: compressor available to me cannot keep up with the air We know all about that don't we @Achto Sand blasting is the quickest. and leaves a good surface to prep for paint, A suggestion would be find a blaster in your area. Auto body shops and places that sell headstones are good places for leads. Explain to them you are restoring an old tractor. That might hit home with many shop owners. Since you are on a budget offer to push broom or other chores for trade. Good luck and let us know if we can help in other ways. Edited yesterday at 03:04 PM by WHX?? 1 3 Share this post Link to post Share on other sites
1968Commando 26 #15 Posted yesterday at 03:40 PM (edited) 37 minutes ago, WHX?? said: We know all about that don't we @Achto Sand blasting is the quickest. and leaves a good surface to prep for paint, A suggestion would be find a blaster in your area. Auto body shops and places that sell headstones are good places for leads. Explain to them you are restoring an old tractor. That might hit home with many shop owners. Since you are on a budget offer to push broom or other chores for trade. Good luck and let us know if we can help in other ways. Thank you I will look into sand blasting and see how much it will cost . Edited yesterday at 03:41 PM by 1968Commando 2 Share this post Link to post Share on other sites
Ed Kennell 39,532 #16 Posted 23 hours ago I use nylon (scotch brite) pads on a 4.5" angle grinder. Please wear full face ,eye ,ear, and breathing protection. 1 Share this post Link to post Share on other sites
1968Commando 26 #17 Posted 22 hours ago 30 minutes ago, Ed Kennell said: I use nylon (scotch brite) pads on a 4.5" angle grinder. Please wear full face ,eye ,ear, and breathing protection. Alrighty well right now I have a wire cup brush but I will look into that as a option too Share this post Link to post Share on other sites
Ed Kennell 39,532 #18 Posted 22 hours ago 1 minute ago, 1968Commando said: I have a wire cup brush I use the cup brushes also. They are more aggressive and sometimes more difficult to control than the flat nylon pads. Share this post Link to post Share on other sites
1968Commando 26 #19 Posted 22 hours ago If I continue to use a cup brush, I’m going to prime and paint the metal will the scuffs or swirls show thru? Share this post Link to post Share on other sites
Handy Don 12,902 #20 Posted 22 hours ago 19 minutes ago, 1968Commando said: If I continue to use a cup brush, I’m going to prime and paint the metal will the scuffs or swirls show thru? Very likely yes. And wire brushing can be slow and tedious. I reserve wire brushing for places where the discs cannot reach. Paint remover discs like these are widely available, faster, and thorough. They can also leave marks, but usually fine enough that the primer will fill them. 1 Share this post Link to post Share on other sites
1968Commando 26 #21 Posted 21 hours ago 30 minutes ago, Handy Don said: Very likely yes. And wire brushing can be slow and tedious. I reserve wire brushing for places where the discs cannot reach. Paint remover discs like these are widely available, faster, and thorough. They can also leave marks, but usually fine enough that the primer will fill them. Is this too strong of a wheel or do you think it would work? Share this post Link to post Share on other sites
Easton Rich 437 #22 Posted 21 hours ago I would wire-wheel it and use a self etching primer. In the end it looks like you spent hours sanding it with sandpaper. Advice from a fellow 68’ Commando owner. Share this post Link to post Share on other sites
1968Commando 26 #23 Posted 20 hours ago 58 minutes ago, Easton Rich said: I would wire-wheel it and use a self etching primer. In the end it looks like you spent hours sanding it with sandpaper. Advice from a fellow 68’ Commando owner. Ok I have the wire wheel so I think I’m going to do this route and then any rust pitting do I grind it and bondo it to smooth it? Share this post Link to post Share on other sites
Easton Rich 437 #25 Posted 19 hours ago A very thin layer of bondo, because if you use to much it’s just more to sand off. Share this post Link to post Share on other sites
