pascal Plancke 8 #1 Posted January 31 Hello, I have recovered a 1977 Wheel Horse C-160/ Kohler K301S, 12hp, nb 47421d serial nb 7382379 equiped with a 3 blades landmower. There is no need to send here a picture as it is such bad condition. Nevertheless, i wish to put is it back on its wheel. I have started to check what is needed as spare parts: - a clean air box and filter is missing. And idea of what parts number/ references are needed ? - the carburator bottom tank is leaking. Where to find a new one in France? - the friction cluch disc is worn. What size ( Diam.) and thickness shall i put in? - the oil filter? No idea where this is located nor what part number to use. Any advise? And is it still possible to find a sketch of the landmower ? Thank you very much in advance to whom may help me Regarrds 5 Share this post Link to post Share on other sites
stevasaurus 23,515 #2 Posted January 31 Welcome to Red Square. These links are from our picture gallery. I am assumiong your horse is a automatic. 1 Share this post Link to post Share on other sites
stevasaurus 23,515 #3 Posted January 31 Here is a manual...there is more in our manual library. 1 1 Share this post Link to post Share on other sites
Ed Kennell 43,783 #4 Posted January 31 So it is a C-160 and the 16 HP K-341 engine has been replaced with a 12HP K301. There should not be an oil filter on the engine or transmission. 1 Share this post Link to post Share on other sites
daveoman1966 3,881 #5 Posted January 31 If you want to see a full range of schematics, with part numbers, go here: https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en Enter your model number EXACTLY as: 71-16KS01 . Clik SEARCH. You see schematics, implement attachments, and a range of other info to help restore the C-160 Auto. ps... I have the exact same tractor....love it. 1 Share this post Link to post Share on other sites
rjg854 12,625 #6 Posted January 31 @pascal Plancke Any picture of a tractor is a good picture, condition has nothing to do with it. Also helps us to see what you're working with and better diagnosis what it needs. 6 1 Share this post Link to post Share on other sites
Retired Wrencher 6,168 #9 Posted February 1 As you can see already much help here. I hope you enjoy the tractor and the ride. 3 Share this post Link to post Share on other sites
Kenneth R Cluley 624 #10 Posted February 1 No worry about condition, from rusty to trailer queens we love em all! 2 Share this post Link to post Share on other sites
pascal Plancke 8 #11 Posted February 2 Hi All, Thank you for your welcome and messages. The side labels clearly indicate C-160 8Speed. But yes, the engine is a 12HP. (so C-120). May be it has been exchanged sometimes... I have not yet seen any oil filter. But so many things are missing. And not easy to find them around here in the middle of nowhere in France. Abviously form what is see on the websites/ webshops that some parts re discountinued ; - the clean air filter box assembly (KH 235100 and KH235) in ex. I also miss: - The carburator bowl (2004185 ?) , -I am also trying to find out what belt size i shoud buy. I think they are 4L 820 (main drive) , 3V1035 and 3V860 ? -The clutch friction disc is also not the guenine one. I has been replace and put in with rivets (diam 6.77') and I can tell what as the original thickness... Good heavy work for the coming days ... Regards Pascal Share this post Link to post Share on other sites
pascal Plancke 8 #12 Posted February 2 On 1/31/2025 at 10:27 PM, daveoman1966 said: If you want to see a full range of schematics, with part numbers, go here: https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro&lang=us_en Enter your model number EXACTLY as: 71-16KS01 . Clik SEARCH. You see schematics, implement attachments, and a range of other info to help restore the C-160 Auto. ps... I have the exact same tractor....love it. Hello Dave, When you say that you have the same, do you mean that your C-160 is also fitted with a 12HP (Kohler K301S)? And where do you find the 71-16KS01 number? regards Pascal Share this post Link to post Share on other sites
daveoman1966 3,881 #13 Posted February 2 (edited) NO-- my c-160 has the original 16hp Kohler engine. I use this Excel SS to determine the model number. It gives detAILS THRU 1984... wh ss.xlsx Edited February 2 by daveoman1966 Share this post Link to post Share on other sites
squonk 44,860 #14 Posted February 2 6 hours ago, pascal Plancke said: Hi All, Thank you for your welcome and messages. The side labels clearly indicate C-160 8Speed. But yes, the engine is a 12HP. (so C-120). May be it has been exchanged sometimes... I have not yet seen any oil filter. But so many things are missing. And not easy to find them around here in the middle of nowhere in France. Abviously form what is see on the websites/ webshops that some parts re discountinued ; - the clean air filter box assembly (KH 235100 and KH235) in ex. I also miss: - The carburator bowl (2004185 ?) , -I am also trying to find out what belt size i shoud buy. I think they are 4L 820 (main drive) , 3V1035 and 3V860 ? - There are no 3V belts used on that tractor. Those are 3/8" wide belts. Drive belt for 71-16KS01 should be 5L840 which is a 21/32" wide by 84" belt. Oil filter for trans goes right behind the trans pulley. Wix 51410 is a number you may be able to cross reference over there. For the fuel bowl you can use a Briggs & Stratton 221995. fits perfectly. Share this post Link to post Share on other sites
Ed Kennell 43,783 #15 Posted February 2 Here's my '75, C-160. The first one I restored. 1 2 Share this post Link to post Share on other sites
pascal Plancke 8 #16 Posted February 4 On 2/2/2025 at 6:56 PM, squonk said: There are no 3V belts used on that tractor. Those are 3/8" wide belts. Drive belt for 71-16KS01 should be 5L840 which is a 21/32" wide by 84" belt. Oil filter for trans goes right behind the trans pulley. Wix 51410 is a number you may be able to cross reference over there. For the fuel bowl you can use a Briggs & Stratton 221995. fits perfectly. Dear Squonk, Thanks a lot for these datas. It helps me to go further in rebuilding this machine. (No problem to find these ref. or equivalences) Regards Pascal 2 1 Share this post Link to post Share on other sites
