Alrashid2 382 #26 Posted January 27 Here's some engine info Two different brand tachs, both set to 1 spark per revolution and they both read correctly now. I found my idle was actually low once I got them reading properly (I find I often get incorrect readings if I don't place it just right on the spark plug boot or wire). My idle was about 1050 rpm. I increased to 1300 rpm. Like a higher idle in case I do drop the throttle too low. High RPM was jumping a lot on my tachs but seemed to be around 3300 rpm. Share this post Link to post Share on other sites
pfrederi 18,314 #27 Posted January 27 Can't address your tac readings but that engine is as Squonk said above. ( I do know that digital multimeters frequently give flaky readings on Kohlers something about the electric aurora) I use the infrared tacks and my favorite is this one. Can't beat mechanical 2 1 Share this post Link to post Share on other sites
ebinmaine 70,550 #28 Posted January 27 1 hour ago, pfrederi said: I use the infrared tacks and my favorite is this one. Can't beat mechanical Does that have a rubber bumper ish thing? Share this post Link to post Share on other sites
pfrederi 18,314 #29 Posted January 27 Yes you just press it against the end of the crank shaft or the PTO shaft 1 Share this post Link to post Share on other sites
ebinmaine 70,550 #30 Posted January 27 1 hour ago, pfrederi said: Yes you just press it against the end of the crank shaft or the PTO shaft Yep. I got one here I'd bought off fleeebay not knowing exactly what it was. Neat piece. Share this post Link to post Share on other sites
Handy Don 13,334 #31 Posted January 27 I am sometimes eccentrically frugal. I’m still happily using a free optical tachometer app on my phone. More than adequate for small engine tuning and the optical lessens the temptation to put body parts in close proximity to moving engine parts. 1 Share this post Link to post Share on other sites
ebinmaine 70,550 #32 Posted January 27 1 hour ago, Handy Don said: free optical tachometer app Tried that. Turns out I'm.. 1 hour ago, Handy Don said: eccentrically frugal. So much that my smart dumb phone don't can't won't do that. 1 Share this post Link to post Share on other sites
