D_Mac
Bolens 1256
D_Mac
Going to possibly pick up a bolens 1256 that's been sitting outside for sometime. My question to any of you who have had one or knows about them is how to get them to free wheel. I would need to push it from a field to a driveway. From what I have read there is a pin on the right hand side, on the hub of the rear wheel that you pull out to get the wheel to free spin. Is there any other tow or dump valve on these machines? Also any thoughts on this model in general. Never had one before. Also never have had a wisconsin engine either. What should I expect?
SylvanLakeWH
If you can't free up the wheels, I've used a plastic slide-a-bogon... just put under the wheel and tow... worked like charm... :twocents-twocents:
  • Excellent 2
953 nut
Or you could put a harness on Jeffrey and have him pull the Bolens out!                  :ychain:         Good luck             :wwp:
  • Haha 1
D_Mac
My sledding days are long behind me and I have never had children I don't have any sleds. If I go get it it will be on sat. I don't know anything about it other then I can have it for 50 bucks and it came with property and new owner wants it gone.
D_Mac
No doubt he could do it. He loves his tractors. He also loves to bite the tires.
953 nut
I used a scrap piece of plywood with a rope run through a couple of holes to slide a Wheel Horse with a frozen-up rear end off a trailer, worked well.  :twocents-02cents:
Feed the poor dog and he may not want to eat tires.         :scratchead:
peter lena
@SylvanLakeWH  that slide abogin  plastic also makes a perfect snow blower CHUTE  BASE SLIDE POINT  , in my snow blower  recoveries , that was always included . personally  think a blower  is a perfect  MAKE IT BETTER PROJECT , similar to a  DOZER PLOW / FRAME SET UP . typically  see , rust , sloppy movement points , basically FIGHTING ITSELF , for me its a glairing  wreck. initial show you the way , is screaming  PTO DRIVE , drive belt will not move the  attachment BY HAND , what could you possibly do ? that plow frame is cake to , correct its  sloppy binding  , "  swing points " ,  kinda like a frozen , choke cable , what could you possibly do ?  frozen ground, pete
Handy Don
A cheap plastic tarp secured over the front lip and then under the plywood will make it even slipperier. My concern with where you are is that the tires might have sunk into the now-frozen soil.
I’d be ready with a jack, some wood blocks, some chain or sturdy rope, maybe even a rock bar & shovel, and another WH or other tractor for pulling.
Kenneth R Cluley
When they are that stuck in ground the old fencepost and fulcrum lever to lift works well since jack usually wont fit underneath. Old mower deck with wheels under tire works well for moving.
D_Mac
Guess I'm going to attempt to get it sat morning. It's a 1970 Bolens 1256. I hope I can get the pin out to free wheel it. Taking a chance on it. 50 bucks worth of fun. I hear the Wisconsin engines are nice. Bolens tube frame so it's a heavy duty piece of machinery. Worst comes to worst I have some yard art.
Edited by D_Mac
oliver2-44
The Wisconsin engines are heavy duty.
If you happen to pull the head you may find the piston stamped some odd number like .015.
Wisconsin machined the bores to match the piston.
Maxwell-8
I had a bolens, they have a worm gear as final drive, that's why they cant free spin in neutral. There should be a pin in one of the hubs you can pull out.
I personally didn't like the transmission on the one I had, way to sloppy
 244979689_856091825101114_4590149392024365715_n.jpg.e0c336ffd3a87b2824ed84238a69ef46.jpgDSC_0465.JPG.947d07ce8484eac9ad3fba10b2822ea1.JPG
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • robertsonchris06@gmail.co
      By robertsonchris06@gmail.co
      After using my 8-25 mower successfully for several years I noticed the belts were very worn. I replaced the belts and used the mower several mowings this past summer with no problems until as I was mowing the last time the mower would not move in any gear. After stopping and inspecting the traction belt it was almost completely destroyed. Prior to this I had noticed that the engage/disengage lever was getting hard to activate (very stiff). Has anyone had a similar thing happen?
      Thanks in advance for any help on this problem.
      Just want to keep my mower running.
      Chris
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
    • 87buickt
      By 87buickt
      Newb here, recently purchased a b310 that now runs with snow thrower, plow, and mower deck for what I believe to be a good deal for $200. My question to all y’all gurus is what am I missing for my snow thrower attachment? I’d like to get it squared away before winter I know I’m going to need a belt and chain any help would be greatly appreciated.
    • Redcube
      By Redcube
      I need help Identifying my wheelhorse tractor model number 105109 I don't know how to read it
