yhhdghu863
Oil leaking.
yhhdghu863
 I have some oil leaking from the seal behind the clutch. please advice..
oliver2-44
I see you have a 1967 model Wheel Horse. Can you tell us if it has a Kohler or Tecumseh engine.
To help figure out where the leak is coming from get a can of spray brake clean and clean off the oily area. Then run it and watch where the fresh oil is seen.
Picture would help us help you
Edited by oliver2-44
  • Like 3
rjg854
:WRS:  like Oliver posted the more information you can give the forum, the easier it will be to diagnose your leak.
