Andrew hastie 0 #1 Posted January 23 Replacing drive belt on 270h. Belt seems to run very close to other components, need to check belt fitment so hoping for any pics or diagrams. Also, set up of small electrical contact that operates on the clutch. Thanks. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,251 #2 Posted January 23 Model number and serial number would be a help. Share this post Link to post Share on other sites
953 nut 57,986 #3 Posted January 23 Page 3-10 of this manual has what you need. Share this post Link to post Share on other sites
peter lena 9,092 #4 Posted January 25 @Andrew hastie welcome ! while I am not familiar with your model / type , I am very familiar with belt drives , and related linkage / lever set ups . noticing your 2 pulley , IDLER SET UP , those pulleys are known to fail from lubrication failure should move with smooth / easy silence , and also every lever linkage movement point , its the COLLECTIVE BELT DRIVEN , DRAG THAT CAUSES FAILURES , EVERY STAGE OF IT CAN / SHOULD , ENGAGE / MOVE EASILY .ALSO EXCELLENT CHASSIS GREASING OPPORTUNITY , that wiring issue could be corrosion ,and related connection areas . would also check out any fuse areas , like a , ELECTRICAL ENHANCER , aerosol on connections , even GROUNDING AREAS ! good luck , pete Share this post Link to post Share on other sites
