Leo 0 #1 Posted January 21 I'm looking for a parts list for a 42 inch snow blower attachment that is on my C85. Anybody with information on this attachment will be greatly appreciated! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #2 Posted January 21 Here is a list of them to help you identify which one you have Snowthrower DNA All have 2 idler sprockets for the drive chain. Started out as 37" wide and the added wings make them 42" wide. 1966-67 model ST-376 1968 model 6-1211 1969 6-6211 plus 6-9111 1970-72 model 6-6212 plus 6-9112 All without front quick hitch so not a direct fit for 1973 and later tractors. Snowthrower rear frame mounts in the front of the tractor frame using 2 bushings and a long 3/8-16 x 8-1/2" bolt. ------------------------------------------------------------------------------------------------------------ Front quick hitch introduced in 1973. Snowthrower rear frame has a 5/8" diameter round bar for the front quick hitch. 1973-74 model 6-6212 plus 6-9113 1974 model 6-6213 - (First model to include 8-0221 extensions without the front straight return - just a flat plate) 1975 model 6-6214 - (First model to include 8-0221 [103552 replaced by 93-1617 and 93-1617-01] side extensions with the front straight return. First model to have a cable spool on chute rotating crank) Chute crank support decal 104461. 1976 model 6-6215 ------ Chute crank support decal 104461. This one - 1976 model 66-42ST01 - Chute crank support decal 104461. and this one are likely identical. The model number format changed. 1977 model 76-42ST01 - Chute crank support decal 104461. This one 1978 model 86-42ST01 - Chute crank support decal 104461. and this one 1979 model 96-42ST01 - Chute crank support decal 104461. and this one may be all the same. They started using a different model number for each model year. 1980 model 06-42ST01 - (Last 42" model to use 4 grooved rollers for the chute) 1981-82 model 06-42ST02 - (First model to use plastic collar for the chute but was a retrofit for older models. Last model to use wheels) 1983 model 06-42ST03 - (First model to use skids) 1984-87 model 06-42ST04 - (Last model to use a 3/4" diameter driveshaft) 1987-89 model 06-42ST05 - (First model to use a 7/8" diameter driveshaft) 1990 model 06-42ST06 - (Last model to use a cable to turn the chute) 1991-93 model 06-42ST07 - (First model with tall chute retained by 3 individual grooved retainers) 1993-2001 model 79360 - (2001 and earlier will fit 2002-2007 with kit 105-1503) (1994 first year for replaceable blower housing scraper bar) 2002-2007 model 79362 1 Share this post Link to post Share on other sites
Achto 30,204 #3 Posted January 21 After you determine which blower you have, you can find a manual here. https://www.wheelhorseforum.com/files/category/28-snow-blowers/ Share this post Link to post Share on other sites
Leo 0 #4 Posted January 21 Thanks Gwest and Achto. I now know I have a 1979 Model 96-42ST01. Now, All I need to do is locate the bearings to get this project started. Mainly the 101702 Ball bearing and the 101782 Ball bearing. The search is on! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #5 Posted January 22 An old post on the subject For the left side I used a 3/4" 4-bolt cast iron pillow block bearing from a farm supply like Northern Tool. Saves many bucks. https://www.princessauto.com/en/4-bolt-standard-duty-flange-mount-bearing-assemblies/product/PA1000001321?skuId=3870185 Share this post Link to post Share on other sites
