jeff w 4 #1 Posted Thursday at 05:57 PM Will change drive belt (7473) on my C-81 once things start to warm up again. No problem removing side shield etc. Just wondering the correct procedure for removing belt from PTO? Replaced my spindle belt (8411) back in fall and drive belt needs to be replaced before machine goes back to work! Thank you kindly in advance! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,146 #2 Posted Thursday at 06:08 PM Section 5 of this manual describes belt replacement. A good service manual for all years but specific to 1978-79. 1 Share this post Link to post Share on other sites
ri702bill 8,582 #3 Posted Thursday at 10:04 PM Jeff - You need to remove the right side footrest. The is a nut & bolt in the belt cover near the PTO. DO check the condition of the idler pulley & its ball bearing. It is a welded throwaway assembly - not riveted like that of the 1960's tractors..... Share this post Link to post Share on other sites
