PAULFROGSS 4 #1 Posted January 16 Good morning all, New to this site, I have owned a 417-8 since 2000 and love the machine. The engine is starting to smoke at start up and use oil. Looking for a suggestion if I can rebuild ,have someone rebuild, exchange engine or just keep adding about a 1/2 a quart every third mow. I live in Massachusetts. Thank you and stay warm Share this post Link to post Share on other sites
ebinmaine 75,748 #2 Posted January 16 IMHO your best bet would be to contact Lincoln at A to Z Tractor in PA. I think he might be the easiest source for a plug and play Kohler flat twin. There are of course other engine options depending on your desire to put in Fab work or swapping of more parts or wires. 1 Share this post Link to post Share on other sites
Achto 30,194 #3 Posted January 16 (edited) 1 hour ago, PAULFROGSS said: I have owned a 417-8 since 2000 Sounds like your KT17 has had a good life. If your KT17 is a series 1, I would suggest finding a good used KT17 series II or a M18 to replace it. Rebuild kits can be found for your engine less than $300. Need to factor in any machine work also. Edited January 16 by Achto 1 Share this post Link to post Share on other sites
pfrederi 19,266 #4 Posted January 16 I have a few KT17s and one M 18. I love them... but after spending $900 to overhaul an M-18 I will not ever try to overhaul a KT 17 or M18 (same basic engine) Depending on the amount of over/under you need for various parts they are not all readily available and can be costly. Then you have to figure machine shop work will cost double what a single engine overhaul costs. Your 417-8 had a series 2 KT17 which was a better engine but they all wear out. I would just keep adding oil and change/clean spark plugs occasionally. 6 Share this post Link to post Share on other sites
953 nut 63,003 #5 Posted January 16 I agree with Paul @pfrederi on keeping the present engine and attending to maintenance. One word of advice is to check the smell of your engine oil for a gasoline smell. The fuel pump is located on the top of your engine and if the datagram starts to leak it will pump gasoline into the engine oil. This will dilute the oil causing additional engine wear. 4 1 Share this post Link to post Share on other sites
PAULFROGSS 4 #6 Posted January 16 Thank you for the advice. There is gas smell in oil and I will just stay on maintenance.Stay warm Share this post Link to post Share on other sites
ebinmaine 75,748 #7 Posted January 16 5 minutes ago, PAULFROGSS said: gas smell in oil Could be a fuel pump gone bad 2 Share this post Link to post Share on other sites
Ed Kennell 43,783 #8 Posted January 16 (edited) 2 hours ago, pfrederi said: I would just keep adding oil and change/clean spark A few ounces of oil per mowing is a small price to pay for the bug killer accessory. Oh, and to the Edited January 16 by Ed Kennell 2 3 Share this post Link to post Share on other sites
8ntruck 8,332 #9 Posted January 16 If you have a gas smell to the oil, think seriously about rebuilding or replacing the fuel pump - sooner, rather than later. I've got a C-195 with a KT-19 series 1. Runs well, but consumes a lot of oil, mostly through an oil leak. Got to chase that down this year. 2 Share this post Link to post Share on other sites
pfrederi 19,266 #10 Posted January 16 1 hour ago, PAULFROGSS said: Thank you for the advice. There is gas smell in oil and I will just stay on maintenance.Stay warm Get an electric fuel pump..no future danger of gas contaminating the oil. Some get lucky with the cheap ebay China pumps.. I use facet posi-flo pumps made in Elmira NY... 3 2 Share this post Link to post Share on other sites
PAULFROGSS 4 #11 Posted January 16 Sorry no gas smell still might look into electric fuel pump thank you 2 Share this post Link to post Share on other sites
lynnmor 8,254 #12 Posted January 16 2 hours ago, PAULFROGSS said: Sorry no gas smell still might look into electric fuel pump thank you In post #6 you said there was gas smell in the oil. Stop running it till you replace or rebuild the fuel pump and do a complete oil change. Be sure to use the recommended oil. If you are lucky the oil consumption might get better. Share this post Link to post Share on other sites
PAULFROGSS 4 #13 Posted January 16 Thank you fat fingers, there is no gas smell 1 Share this post Link to post Share on other sites
ri702bill 10,571 #14 Posted January 16 7 hours ago, ebinmaine said: Could be a fuel pump gone bad Hmmm... we know it smokes, does it also steal hubcaps and siphon gas out of the car???? 3 Share this post Link to post Share on other sites
