Epayne85
Raider 12
Epayne85
Hello all, I have a Raider 12 I believe to be a 1970. The deck that came on the tractor is in rough shape and I’d like to either fix it or find one in better shape for next mowing season. If any one has the model # of the deck that would be greatly appreciated!! There is no serial tag on the deck that I have found!
ebinmaine
:text-welcomewave:
Could you post pics of the deck you have and also the front of the frame of the tractor?
Epayne85
I certainly will when I get home, it’s a 3 blade deck mid mount if that helps. It’ll be a week or so before I’m able to get pictures
ebinmaine
No worries.
The pics will show us what you have.. and what your options are.
Achto
:WRS:
I have a '68 raider 12, my go to plow mule.
Here is al link for the manuals and attachment pdf's
  • Excellent 2
953 nut
:WRS:
This manual will show you what will directly interchange on your :wh:.  If you add a mule drive to the front of the Raider you could use newer decks too.
Epayne85
1 hour ago, Achto said:
:WRS:
Love the plow setup I definitely want one for my tractor!
Epayne85
This is the front of my raider
  • Excellent 5
ebinmaine
11 hours ago, 953 nut said:
add a mule drive
This is why I wanted a picture.
I agree.  Add a later type mule and you'll really open up the possibilities.
pfrederi
Actually he has a front mule drive.  The very first mule drive was a short lived item.  It had a big steel plate on the front which has been removed from his. Do not believe the lack of a plate changes the functionality.  Look at these pics an envision the big plate removed.
  • Excellent 4
Epayne85
I have the plate for the front, one bolt was loose and the other was missing just took it off for the time being
Epayne85
I was hoping to find the vin plate on mower deck, or find a newer one that would be even better lol
ebinmaine
With that newer mule drive you can use a bunch of different decks over a broad year range.
kpinnc
Hard to verify from the pic, but I think he'll need to get a belly hitch to use Tach-a-matic decks.
Epayne85
It has the belly hitch
gwest_ca
Is your deck a 36" width of cut?
Found some of the applications for this idler assembly.
Models 5-7365, 5-7366, 5-0600 and 5-0601 are 36" rear discharge decks.
Models 5-0710 and 5-0711 are 36" side discharge decks.
If a replacement deck can be found one using blades with a 3/4" center hole would be a bonus. The 5/8" x 3/4" double-D hole blades may not be available.
Epayne85
It’s a side discharge, I’m almost certain it’s a 36” being it has 3 blades
gwest_ca
Mower Rotary 1971 36in SD model 5-0710
Mower DNA
1971 model 5-0710 replaced by
1971 model 5-0711
1972 model 5-0720
1973-1974 model 5-0721
1975 model 5-0722
1976 model 65-36MS01
1977 model 75-36MS01
1977 model 75-36MS02
1978 model 85-36MS01
1979 model 95-36MS00  - These decks use blades with 5/8" x 3/4" center hole unless the spindle has been upgraded
1979 model 95-36MS01 replaced by
1980-1982 model 05-36MS01 - Last year for bearings with 3/4" ID
1983-1984 model 05-36MS02 - First year for bearings with 17mm ID unless older spindles were updated. These decks use blades with a 3/4" center hole
Note - 17mm is .669"
Epayne85
What’s the difference in a charger 12 vs. the raider 12
kpinnc
Chargers were hydro transmissions. Raiders were manual 6-speed transmissions.
Epayne85
Ok, thank you. I found a charger that looked like my raider just wondering if parts were interchangeable amongst the two tractors?
ebinmaine
The mowing deck should be.
Implements usually swap from manual to hydro just fine.
The tractors have some interchangeable parts like engine,  frame,  hood, fender.
The transmission tunnel/ steering tower  is different.
Epayne85
Lee1977
If it's like my 71 Raider It has a hitch with out the spring latch, have to pin it shut.
Epayne85
Yep, same style I currently have
