Wayne0 588 #1 Posted January 11 Finally got some seat time on Ole' Rusty. Note the "down pressure" on the blade. 12 5 Share this post Link to post Share on other sites
ebinmaine 68,912 #2 Posted January 11 1 hour ago, Wayne0 said: . Note the "down pressure" on the blade. Nicely done! Share this post Link to post Share on other sites
rmaynard 15,737 #3 Posted January 11 I enjoyed my seat time on Monday. And again this morning there was 1-1/2". In reference to downward pressure, I've never had a need for it, nor do I see a reason for it. It's snow. It's not like you are grading stones or dirt. It just looks to me like you are putting excessive wear on the blade. If you can elaborate, I'd appreciate it. 4 Share this post Link to post Share on other sites
ebinmaine 68,912 #4 Posted January 11 13 minutes ago, rmaynard said: I enjoyed my seat time on Monday. And again this morning there was 1-1/2". In reference to downward pressure, I've never had a need for it, nor do I see a reason for it. It's snow. It's not like you are grading stones or dirt. It just looks to me like you are putting excessive wear on the blade. If you can elaborate, I'd appreciate it. We use down pressure here for snow that's been driven on, or a very heavy almost slush type. Also occasionally for scraping up ice. 1 Share this post Link to post Share on other sites
Wayne0 588 #5 Posted January 11 (edited) Yeah, I like to scrape down to the asphalt, so if it rains it runs off and I don't have a skating rink for a driveway. My "down pressure" still allows the blade to float some. As far as wear, the blade is brand new and doesn't get that much use. Big snow gets the big deuce on the 520. Edited January 11 by Wayne0 2 Share this post Link to post Share on other sites
Ed Kennell 39,280 #6 Posted January 11 2 hours ago, Wayne0 said: Note the "down pressure" Is that chunk of rail about 50lbs. ? What happens when the blade trips? I have 50 on the front wheels to improve steering but non on the blade. 4 Share this post Link to post Share on other sites
Skwerl58 730 #7 Posted Sunday at 02:03 AM Nice set up and glad you got the seat time. I also got some seat time pushing snow today. We had 3-4 inches and the first time I pushed the stuff in three years. I have converted a mule drive to hold the weight on my 414-8. 1 Share this post Link to post Share on other sites
c-series don 9,076 #8 Posted Sunday at 02:08 AM (edited) I see you have a GT-1800 with hydraulic lift. Why not just use the solid lift link so you have down pressure? You can actually lift the front wheels off the ground. And if you use the slotted hole in the plow frame it will allow the blade to float a bit. I’m curious like Ed is about what happens when the blade trips? Edited Sunday at 02:11 AM by c-series don 1 Share this post Link to post Share on other sites
Chaz54 67 #9 Posted Sunday at 02:36 AM Here in Missouri I got quite a bit of seat time yesterday and today. We got 4” of snow and sleet and then another 2” of snow two later. I got our driveway cleared after the sleet and snow and again after the 2” of snow. Today I went out and cleared the two neighbors driveway, cleared the street in front of their mailboxes, and to allow parking on the street. The snow on the street was about as deep as the height of the blade. It was 33 degrees out today so the snow was starting to soften up a bit, but the 520H worked beautifully. I don’t use any weights or chains. I switched over to golf cart tires about 3 years ago and really like them. Plenty of traction and not any marks from chains on the neighbors driveways. Made some piles about 3 feet high and 8-10 feet long. 4 1 Share this post Link to post Share on other sites
Wayne0 588 #10 Posted Sunday at 02:07 PM 14 hours ago, Ed Kennell said: Is that chunk of rail about 50lbs. ? What happens when the blade trips? I have 50 on the front wheels to improve steering but non on the blade. Yup around 50 Lbs. The blade pops right back. 2 Share this post Link to post Share on other sites
Wayne0 588 #11 Posted Sunday at 02:10 PM 11 hours ago, c-series don said: I see you have a GT-1800 with hydraulic lift. Why not just use the solid lift link so you have down pressure? You can actually lift the front wheels off the ground. And if you use the slotted hole in the plow frame it will allow the blade to float a bit. I’m curious like Ed is about what happens when the blade trips? I still wanted the blade to float a bit and not dig up the dirt between the driveway and the shed. 1 Share this post Link to post Share on other sites
ebinmaine 68,912 #12 Posted Sunday at 04:05 PM 16 hours ago, Ed Kennell said: Is that chunk of rail about 50lbs. ? What happens when the blade trips? I have 50 on the front wheels to improve steering but non on the blade. 13 hours ago, c-series don said: I see you have a GT-1800 with hydraulic lift. Why not just use the solid lift link so you have down pressure? You can actually lift the front wheels off the ground. And if you use the slotted hole in the plow frame it will allow the blade to float a bit. I’m curious like Ed is about what happens when the blade trips? 1 hour ago, Wayne0 said: Yup around 50 Lbs. The blade pops right back. That's kinda what my big wide 60" plow does. That has a 4" tall by 1/2" thick skidsteer cutting edge. That edge weighs quite a bit. I have FOUR trip springs. Works perfectly. Share this post Link to post Share on other sites
MainelyWheelhorse 669 #13 Posted Sunday at 09:06 PM Today’s plowing session was about a 1/2 hr/45 min of seat time with no issues. I have the blade floating a bit and it never caught anything. The next project is fixing the rattling of the plow and the rod that engages the pin that locks the pivot. 2 1 Share this post Link to post Share on other sites
peter lena 8,888 #14 Posted Sunday at 10:44 PM @MainelyWheelhorse that would be the plow steering quadrant , functional detailing , like , this that entire needs detailing , this lever swing point is a perfect example of , dialing in a movement area , the shoulder bolt , has no threads , in the swing area , red grease makes move with ease , elastic lock nut holds perfect swing base , the pull wire goes to the quadrant , slide pin , also red grease , those plows are cake for functional movement detailing , build mine , up on milk crates , so I can watch the changes , easy to roller stool around , and verify its easy use. that hand squeeze lever , moves without effort , blade swing effortless . also oil lubricate the front of blade , for snow slide off , like free HP , pete 2 Share this post Link to post Share on other sites
MainelyWheelhorse 669 #15 Posted Sunday at 11:17 PM (edited) @peter lena The plow works fine. It’s at least 50 years old and well used before I bought it. I know it’s not the triangle/quadrant as that is tight and lubed. It’s the rod that swings the plow pivot. It floats in the holes and the vibration from the engine rattles it every so often. I lubed everything that moves on the plow before I put it on in September. Thanks though for the tip abut oiling the front of the blade. Edited Sunday at 11:58 PM by MainelyWheelhorse 1 Share this post Link to post Share on other sites
peter lena 8,888 #16 Posted Sunday at 11:31 PM @ MAINLY WHEEL horse , that wire pull , found that using a small pair of channel locks , to snup up the connection points , makes a difference , also on the starting downward wire track , ran it thru some small plastic tubing to enhance slide , then used the small channel locks to snug up the connection points , basically eliminating and sloppiness in initial lever squeeze, have a couple of blades , no slack in lever pull , remember the PLOW STEERING QUADRANT COMPRESSION SPRING , tensions the entire lever set up , pete 1 Share this post Link to post Share on other sites
bassJAM 57 #17 Posted Tuesday at 10:27 PM (edited) On 1/11/2025 at 6:55 PM, Ed Kennell said: Is that chunk of rail about 50lbs. ? What happens when the blade trips? I have 50 on the front wheels to improve steering but non on the blade. I added 120lbs to the front axle this year, it made a world of difference vs nothing before except washer fluid in the tires. I've never needed down pressure but my font end would get pushed around when the plow was angled. Edited Wednesday at 09:45 PM by bassJAM 3 2 Share this post Link to post Share on other sites
Retired Wrencher 5,539 #18 Posted 15 hours ago On 1/11/2025 at 6:21 PM, Wayne0 said: Yeah, I like to scrape down to the asphalt, so if it rains it runs off and I don't have a skating rink for a driveway. My "down pressure" still allows the blade to float some. As far as wear, the blade is brand new and doesn't get that much use. Big snow gets the big deuce on the 520. Wane0 I agree with you and Eric, I use down pressure all the time. I like how it gets down to the pavement.I do not put a lot of pressure on the handle just enuf to move the snow after blowing first. Now ice is different. 2 Share this post Link to post Share on other sites
