Mark siebenaler 107 #1 Posted Saturday at 08:17 PM I recently acquired a k241as 10 hp That was removed from a jd 210 It has a very shallow oil pan maybe one inch deep. My question is with this oil pan would it ever work in a wheelhorse tractor? Or do I need to find a deeper oil pan. Share this post Link to post Share on other sites
rmaynard 15,706 #2 Posted Saturday at 08:37 PM The 1978, 79 C-101 used a K241AS. Not sure if it's directly compatible. Share this post Link to post Share on other sites
squonk 41,604 #3 Posted Saturday at 09:25 PM If you found a deep pan that would work you would also need the connecting rod with a longer oil dipper. 1 Share this post Link to post Share on other sites
pfrederi 17,959 #4 Posted Sunday at 12:14 AM If you can bolt it on and have the crank at the right height it will be fine... Share this post Link to post Share on other sites
ebinmaine 68,742 #5 Posted Sunday at 01:03 AM 4 hours ago, Mark siebenaler said: k241as Got any pics? Share this post Link to post Share on other sites
oliver2-44 9,907 #6 Posted Sunday at 01:27 AM (edited) The mid1960's ( 1045 if I recall correctly) use a flat shallow 1" pan to fit the 10hp large block kohler under the hood. The connecting rod had a short dipper on it. Edited Sunday at 02:21 AM by oliver2-44 1 Share this post Link to post Share on other sites
Maxwell-8 4,358 #7 Posted Sunday at 08:37 AM Maybe mounting it an a shaker plate? 1 Share this post Link to post Share on other sites
ebinmaine 68,742 #8 Posted Sunday at 12:13 PM 3 hours ago, Maxwell-8 said: Maybe mounting it an a shaker plate? That's what was wondering too. Plate. Adapter. Set of four bolts. Whatever works. 1 Share this post Link to post Share on other sites
953 nut 56,091 #9 Posted Sunday at 12:20 PM Here is a thread that will give you the information you need on the different Kohler oil pan configurations. 1 1 Share this post Link to post Share on other sites
Mark siebenaler 107 #10 Posted Sunday at 02:13 PM 2 Share this post Link to post Share on other sites
ebinmaine 68,742 #11 Posted Sunday at 02:25 PM I believe you have 2 options. 1. Use that just as it is by adapting the existing bolt holes to the Wheelhorse frame with a plate and set the correct height. 2. Get a setup from a Wheelhorse of the 1978 ish to 1982 ish period and use that lower frame adapter with solid mounts. Personally I'd try the first. If you do decide to swap that oil pan I'd be interested in buying the one you have now. 1 Share this post Link to post Share on other sites
