Nicholas varricchio 0 #1 Posted January 4 My name's Nick varricchio I have a 310-8 wheel horse toro I'm rebuilding I'm in need of a snow plow or dozer blade that I could part together Share this post Link to post Share on other sites
WHX?? 50,638 #2 Posted January 4 Nick Best off posting a want ad here. https://www.wheelhorseforum.com/classifieds/wanted/ Share this post Link to post Share on other sites
Ed Kennell 40,415 #3 Posted January 4 (edited) to the Nick. Yes, post a wanted ad here and look on the for sale sites in your area. If you don't have one, you will also need an axle bracket. An axle bracket can be seen hanging on this long frame on the right. This is the frame you need for your 310-8. Note the different shape on the short frame on the right. The blades are available in 42,48, and 54" widths. e Edited January 4 by Ed Kennell 4 Share this post Link to post Share on other sites
peter lena 9,075 #4 Posted January 4 @Nicholas varricchio like a hitch pin clip , on the rear axel bracket levers , push it thru the small matching holes , lever / bracket , areas , push thru to last end hole , that way , they will not fall out , local H/W store has them 1/8" , lube while there , pete Share this post Link to post Share on other sites
953 nut 57,768 #6 Posted January 5 @Sparky may have one he would sell though he is a few hundred miles away. 1 Share this post Link to post Share on other sites
