Jrblanke 885 #1 Posted January 4 Good evening y'all and Happy New Year! I've had a couple weeks off work during the holiday's and of course, and as most folks do, I browsed the facebook marketplace listings to see what's out there! I saw this Electro 12 listed as "wheel horse". That was it! I decided to use the excuse of not having a running truck as the reason for not going to buy it. (Though i'm sure @Wheel-N-It would have been more than happy to let me borrow a trailer). So anyways, I got to thinkin, I really don't know much about the Electro, Charger, or Raider. I assume they are from 1968-1972ish? Did they have numbered tractors during these years? Like the 857 would have been an 8hp from 1967, and a 1056 would be a 10hp from 1966. I know the Commando started in 1968, so I assume the electro, charger, raider were the just the higher horsepower versions. But im not sure what the names mean, or if they are for a specific horsepower or transmission. I thought the electro meant that it had an electronic PTO. Were all electros 12 hp? Were all electros automatics? What about chargers and raiders? Here is the electro 12 that was listed locally for $300 bucks. It has since sold. It was a nice tractor! I almost regret not going to get it! 1 1 Share this post Link to post Share on other sites
AlexR 1,270 #2 Posted January 4 Not sure about Electro's I think you might be into it though because every electro I have seen has a electric pto But Raiders are manual's I believe 10-14hp and Chargers are automatic's also I believe 10-14hp 1 Share this post Link to post Share on other sites
kpinnc 13,702 #4 Posted January 4 (edited) 1 hour ago, AlexR said: Not sure about Electro's I think you might be into it though because every electro I have seen has a electric pto But Raiders are manual's I believe 10-14hp and Chargers are automatic's also I believe 10-14hp Pretty much spot-on. In the late 60s Wheel Horse tried using names for models instead of numbers. Commando- 3 speed and 8hp Raiders- 6 speed transmission. 9-12hp. Chargers- hydro and manual lift. 9-12 hp. Electro- hydro, manual lift 12hp and electric PTO. Bronco- 1971 and 72 only, 14hp, hydro with hydraulic lift. Electric PTO. I think 1968-70 had the hood like the first picture above. 1971 and up had the hoods more like the early C-series. Edited January 4 by kpinnc 3 1 Share this post Link to post Share on other sites
siebenaler 114 #5 Posted January 4 I have a electro 12 and it has a hydraulic lift. ?. I also replaced the electric pto To manual pto. Good plow tractor. 1 Share this post Link to post Share on other sites
kpinnc 13,702 #6 Posted January 4 31 minutes ago, Mark siebenaler said: I have a electro 12 and it has a hydraulic lift. I honestly don't remember if that was standard or not on the early Electro. But I do know that adding hydraulic lift was an option on any Sundstrand hydro. 1 1 Share this post Link to post Share on other sites
ebinmaine 70,653 #7 Posted January 4 7 hours ago, kpinnc said: I think 1968-70 had the hood like the first picture above. 1971 and up had the hoods more like the early C-series. 1970 was the first year of the later style hood. 2 1 Share this post Link to post Share on other sites
AlexR 1,270 #8 Posted January 4 (edited) 9 hours ago, kpinnc said: Raiders- 6 speed transmission. 9-12hp. I have a 1972 Raider 14hp and it has a 8 speed but 1972 was the only year they made a 14hp 8 speed, model number 1-0320 I don't believe they made a Charger 14hp though, so I was not correct there. Probably because of the Bronco. Edited January 4 by AlexR 2 1 Share this post Link to post Share on other sites
pfrederi 18,322 #9 Posted January 4 (edited) Electros had hydro lift and electric PTO and Chrome Hub caps (They were gold plated Chargers...sort of like Mercurys were gold plated Fords ...for you old guys) The Chargers and Electros were made for were made 1968-72 Lots of variation over time. Very Early models had Starter Generators. Kohler was experimenting with ignition systems and depending on the year you could wind up with a battery points system, a magneto points system or the breakerless (First try at an electronic ignition) They had 10 pinion LSD differential 1-1/8" axles. They are my favorite WHs (I have six) They make fantastic snow machines with the LSD. The sunstrand hydros were also a bit faster than the later eatons. (I do not polish or lube my snow plow blades ..stuff just rolls of at 7mph) Would have been nice if they had a couple more HP for snowblowing (I up engined two of mine to 16hp) Edit: Forgot to add the Charger 9 and 10 had a 10hp Techy engine Edited January 4 by pfrederi 3 2 1 Share this post Link to post Share on other sites
Jrblanke 885 #10 Posted January 4 Thanks for all the replies! I think I like the electro/raider/charger because of the mid 60s styling, but they put the floor boards on it instead of the stirrups. 2 Share this post Link to post Share on other sites
ebinmaine 70,653 #11 Posted January 5 31 minutes ago, Jrblanke said: Thanks for all the replies! I think I like the electro/raider/charger because of the mid 60s styling, but they put the floor boards on it instead of the stirrups. I agree with that but they still only had one foot pedal. I'm a two pedal fan. Separate clutch and brake pedals. Share this post Link to post Share on other sites
pfrederi 18,322 #12 Posted January 5 Brakes... who needs stinking brakes. none of my early sunstrands have brakes. Haven't' crashed in to anything yet 3 Share this post Link to post Share on other sites
ebinmaine 70,653 #13 Posted January 5 Just now, pfrederi said: Brakes... who needs stinking brakes. none of my early sunstrands have brakes. Haven't' crashed in to anything yet Yeah. ..... some of us like a manual transmission. Share this post Link to post Share on other sites
Ed Kennell 40,453 #14 Posted January 5 33 minutes ago, pfrederi said: Brakes... who needs stinking brakes. Freddy Share this post Link to post Share on other sites
kpinnc 13,702 #15 Posted January 5 15 hours ago, AlexR said: I have a 1972 Raider 14hp and it has a 8 speed but 1972 was the only year they made a 14hp 8 speed, model number 1-0320 I was thinking they made a Raider 14, but couldn't remember for certain. I must be slipping! 1 1 Share this post Link to post Share on other sites
ebinmaine 70,653 #16 Posted January 5 7 hours ago, kpinnc said: I was thinking they made a Raider 14, but couldn't remember for certain. I must be slipping! Don't worry about it K. P. The rest of us'll cover for ya. I was told many moons ago to initiate using post it notes 📝 to remember things. It's a good useful tool. 4 Share this post Link to post Share on other sites
