Easton Rich
Steven The Commando/B-80 Puller
Easton Rich
Easton Rich
Was it bored?
Achto
18 hours ago, Easton Rich said:
Check your local rules. Our club does not allow the velocity stack adaptor ring in "stock" class. We can run that type of air filter but it has to be adapted to a stock backing plate.
ebinmaine
1 hour ago, Easton Rich said:
Was it bored?
Double check the top of the piston. I can't quite read it.
Does it read "STD" ?
Achto
@Achto how did you build your cover over your drive pulley on your tractor you called 2024 project
My 2024 project ended up getting named "Horse Apples", mainly because it was built on the cheap with parts and materials that I had laying around. AKA, a bunch of Horse crap thrown together. The rear fender sports a decal that says "Built with poor decisions and no money"
As far as the front cover,  (our club rules state no exposed belt). Started with a flat piece of 16ga sheet metal, did a little cuttin', a little bendin', a little weldin', drilled some holes and bam!! One cover. The whole thing was measured with a micrometer, marked with chalk, and cut with an axe. :D Sorry didn't document any dimensions.
Achto
Was it bored?
I see STD on the piston, this would indicate standers bore.
Boring the cylinder .030 over will gain your a little power, very little though.
ebinmaine
Do you know the technical reason for that?
Do they make a HP difference?
TonyToro Jr.
Our club has the same rule. I don’t really know the technical reason. But I do think they gain a bit of power depending on how long the velocity stack is. For example on Super stocks some are over 10” long.
Achto
3 hours ago, Easton Rich said:
No stock -modified
Not sure what you club considers modified. In my club if your not moving 15+mph in mod class, your not going to compete. How do you achieve 15mph ground speed while pulling? Easy - throw money at your tractor. HP = $
Here is a lot of reading for you on Garden tractor pulling.
https://gardentractorpullingtips.com/index.htm
For tires, If you are going to pull in a Mod or Improved class I would suggest going to a pulling tire instead of an ag tire. Something on this line.
https://vogelmanufacturing.com/vm10-tires-mounted-on-vm-wheels.html
Our club allows us to run this type of tire in the stock class but, our hitch height has to be dropped to 12". If you are running ags like I have on Horse Apples (26x12x12 Firestones), then they allowed a 13" hitch height.
Horse Apples pulls in stock class. A good "stock" Kohler engine in our club will have the head shaved, but there must be a visible line where the gasket surface is. A cam shaft from a 18hp OHV K361, very hard to find usually around $350 if you find one. You can also send your cam out to be welded & machined to the K361 spec for around $350ish. A good 12 angle valve job to ensure a good seal. A carb from a 16hp engine, max venturi 1.25". No porting or polishing allowed. Max over bore of .030". Over boring does give a minute HP gain, nothing that you will feel in the seat though.
Not trying to sway any decisions on what class to run. Mods are very cool !!! Just saying dig into your rules so that you have the knowledge to compete.
Achto
There is some gain there. The whole funnel effect over abrupt change. Still running a bone stock air cleaner with a K&N filter on mine.
ebinmaine
I quoted this because it bears repeating.
Get the rules for the next season IN WRITING.
Do your build with a full understanding of what you have vs what you want and make ALL the changes as a whole.
Easton Rich
Ok this is starting to make more sense as I go
Easton Rich
@Achto How much did it cost to have your kseries head shaved?
ebinmaine
On 1/3/2025 at 9:21 PM, ebinmaine said:
I can show pics with the difference between the Kohler hood and Tecumseh hood tomorrow.
The Tecumseh is an OHV160.
Over Head Valve.
Much taller engine than the Kohler.
The hood hinge is maybe 1.5" taller.
@Easton Rich
Here's 4 pics of hood hinges.
Top two are Kohler K341 Powered.
Numbers 3 and 4 are from OHV160 Tecumseh engine tractors.
Note the extra height of the Tecumseh hinges.
Easton Rich
Wow that’s a very large difference
Easton Rich
A built a hinge by combining the Commando and the b-80 hinge (yes I drilled in them)
Easton Rich
What wheel are you running to have those tires on?
Achto
I believe it was around $75
Achto
My rims have a 4 / 8 offset, can be mounted either way. Mine are mounted with the 4" offset to the inside. I do have to run a 3/8" spacer behind them, only because the center hole on the rim is smaller than center on the hub. This will be typical of most aluminum rims. They will also have 1/2" mounting holes with no taper. Mine are mounted with regular 7/16" grade 8 bolts & washers.
Edited by Achto
Easton Rich
Ok, what brand are your wheels?
Easton Rich
I’ve done a little research on converting it to a regular starter, but I’m still not 100% on it. Have any of you done it?
ebinmaine
What a regular starter and what's on there now?
Easton Rich
It would be a S/G but I want to convert it to a regular charging system/starter
ebinmaine
On a very early Commando 8  you'd have seen a S/G.
******  You're changing to a Different engine right?
Wiring is easy enough on these tractors.
It's very basic.
Is there any wiring left in the tractor?
What type of ignition switch is in there?
Handy Don
Not at all straightforward.
A “regular” starter needs the starter itself, mounting bosses in the block casting, a flywheel with teeth on the circumference, and a shroud shaped to cover the flywheel and the place where the starter bendix engages the flywheel.
A “regular” charging system needs a stator mounted between the bearing plate and the flywheel, a flywheel with magnets on the inside circumference to energize the stator, and the proper voltage regulator (an S/G regulator will not work).
An S/G engine will not have the necessary bosses, flywheel, stator, or shroud and on some tractors (the 854 comes to mind), the location of the battery box would interfere with a “regular starter” Kohler K181 anyway
Assuming it’ll fit, change engines.
Edited by Handy Don
