PhilD
Steel wire diameter
PhilD
Hi , Happy New Year Everyone. I need the wire that attaches from the plow angle handle to the little bracket below that allows you to angle the blade. It’s a thin wire , I thought I’d ask before buying a bunch of different sizes for trial and error.  Thanks
SylvanLakeWH
'Bout coat hanger size... or the size they use to hang ceiling tiles... or around 9 gauge...
peter lena
@PhilD   note , how elastic lock nuts , hold perfect movement setting , also strive for squeeze lever , zero play , for maximum rod to  steering quadrant movement pull  , lubricate as you go , like penetrating oil and red spray grease , that plow can and should move with total solid ease , sound like a rifle bolt . hitch pin clips at rear axel lever stops , pete
moe1965
The wire that are used for yard signes works great
oliver2-44
Achto
:text-yeahthat:Straighten out an old wire coat hanger that you probably have laying around some where. This is what I did with mine, works great.:thumbs2:
Edited by Achto
Chaz54
I just measured the wire on my plow and it measures 0.122” or about 8 gauge. A coat hanger measures 0.090” or about 11 gauge wire. There is 9 gauge project wire at Lowe’s that would work for you.
Edited by Chaz54
