peter lena 9,085 #1 Posted December 26, 2024 @stevasaurus found it ! this is the way you remove deck pulleys / spindles , note pictures for leverage . bolt points under pulleys , penetrating oil , pulleys lift right off, off , also regularly refer to spindle bearings , those 6203 / similar are also a very common ceiling bearing , with pathetic light duty grease , the spindle whyining is telling you of lube failure , regular for me to , carefully remove side shields , wipe out / flush with carb cleaner , re pack with lucas green xtra HD chassis grease , also do the same on mule drive bearings , tell me how that works . if you look at the top of deck to pulley side picture , you will see a flat idler pulley up against the very long unsupported deck drive belt , not belt bounce , using this set up for years , bombproof , went after every stage , and made it better , 2 wonder bars on top of spindle deck mount bolts , snug fit on both leverage wonder bar swing outward solid leverage , put inside of W/B edge up against the pulley down slide area . pulley lift off is solid smooth , this entire set up was a look / see , for me , once verified , added steps to every related bearing failure area , 12 bearings alone on mule drive , this works , pete Share this post Link to post Share on other sites
Brockport Bill 1,822 #2 Posted December 26, 2024 21 minutes ago, peter lena said: @stevasaurus found it ! this is the way you remove deck pulleys / spindles , note pictures for leverage . bolt points under pulleys , penetrating oil , pulleys lift right off, off , also regularly refer to spindle bearings , those 6203 / similar are also a very common ceiling bearing , with pathetic light duty grease , the spindle whyining is telling you of lube failure , regular for me to , carefully remove side shields , wipe out / flush with carb cleaner , re pack with lucas green xtra HD chassis grease , also do the same on mule drive bearings , tell me how that works . if you look at the top of deck to pulley side picture , you will see a flat idler pulley up against the very long unsupported deck drive belt , not belt bounce , using this set up for years , bombproof , went after every stage , and made it better , 2 wonder bars on top of spindle deck mount bolts , snug fit on both leverage wonder bar swing outward solid leverage , put inside of W/B edge up against the pulley down slide area . pulley lift off is solid smooth , this entire set up was a look / see , for me , once verified , added steps to every related bearing failure area , 12 bearings alone on mule drive , this works , pete Pete -- bought the wonder ( pry ) bars at your suggestion last year -- they have been nice tools to have for multiple uses but still could not get the fozen pulleys off the 42 rd deck -- thats why ultimately i had to cut off Bars are good suggestion and likely will remove many rusted pulleys -- but not the two i couldnt remove -- UGH !! Share this post Link to post Share on other sites
peter lena 9,085 #3 Posted December 27, 2024 @Brockport Bill thanks for the reply , wow that set up must have been solid rust , something I have been doing on any, possible rust area , is to use the natural vibration of the tractor , to get a penetrant into , long frozen , anything . like upper pulley top nut removal , and a kroil soak , that also works very well , on a rear hub removal plan remove set screws , at 12 noon location , so lube can set and hold yo the axel / threading area , maybe a dead blow hammer , to assist . before doing my mower decks , would start kroil soaking anything weeks out , sure enough , just about anything had a wet rust tracking , coming from it .never liked the idea of a , puller on those spindles , thats their weakest point ! personally was amazed at how easily those pulleys moved off , very solid , smooth . often refer to something I have tried / experimented with . never expect it to initially work , my war on corrosion , has been constant , why not try something ? hope you and yours had a good christmas , pete 1 Share this post Link to post Share on other sites
76c12091520h 3,785 #4 Posted December 28, 2024 On 12/26/2024 at 12:24 PM, Brockport Bill said: Pete -- bought the wonder ( pry ) bars at your suggestion last year -- they have been nice tools to have for multiple uses but still could not get the fozen pulleys off the 42 rd deck -- thats why ultimately i had to cut off Bars are good suggestion and likely will remove many rusted pulleys -- but not the two i couldnt remove -- UGH !! Same thing here, likely parted out 50+ decks over the last few years. Pry bars might work 10% of the time on these styles of pulleys.....even after soaking/ heating for days or even weeks. 1 Share this post Link to post Share on other sites
