Retired Wrencher 6,166 #1 Posted December 25, 2024 (edited) Hi I am looking for a column for a 1056 as you can see this was broken by the P/O. Is there info on length of these steering shafts. I have some extra parts form a 856 that does not work to short. any info would be great full. Edited December 25, 2024 by Retired Wrencher Share this post Link to post Share on other sites
ebinmaine 75,689 #2 Posted December 25, 2024 Which piece do you need? The 3/4" round shaft that the steering wheel is on? Share this post Link to post Share on other sites
JimSraj 560 #3 Posted December 25, 2024 I have this, as well as other parts, from a 1267 (I think) that I’m going to be parting out after the holidays. 2 Share this post Link to post Share on other sites
ebinmaine 75,689 #4 Posted December 25, 2024 4 minutes ago, JimSraj said: I have this, as well as other parts, from a 1267 (I think) that I’m going to be parting out after the holidays. Jim if that PTO handle hoop and battery box is solid - I'd be interested... Share this post Link to post Share on other sites
JimSraj 560 #5 Posted December 25, 2024 Eric, The battery box is solid. It was bent a little but I was able to bend it back pretty well with an adjustable wrench. The PTO shaft hoop is in good shape. I also have the handle as well as the clutch. I’ll have a look around to see if there is anything else PTO related if you are interested. I get some close up pictures for you later. 1 Share this post Link to post Share on other sites
Blasterdad 3,066 #6 Posted December 25, 2024 Why can't you just put a new steering wheel on the shaft that's on it? 1 Share this post Link to post Share on other sites
ebinmaine 75,689 #7 Posted December 25, 2024 13 minutes ago, JimSraj said: Eric, The battery box is solid. It was bent a little but I was able to bend it back pretty well with an adjustable wrench. The PTO shaft hoop is in good shape. I also have the handle as well as the clutch. I’ll have a look around to see if there is anything else PTO related if you are interested. I get some close up pictures for you later. PM sent Share this post Link to post Share on other sites
Retired Wrencher 6,166 #8 Posted December 25, 2024 6 hours ago, ebinmaine said: Which piece do you need? The 3/4" round shaft that the steering wheel is on? Yes the shaft I may have a friend who may have a press. But will not be till spring. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,166 #9 Posted December 25, 2024 (edited) 5 hours ago, ebinmaine said: Jim if that PTO handle hoop and battery box is solid - I'd be interested... Jim I would be interested in the hole console or just the shaft and steering wheel. Edited December 25, 2024 by Retired Wrencher 1 Share this post Link to post Share on other sites
Retired Wrencher 6,166 #10 Posted December 25, 2024 4 hours ago, Blasterdad said: Why can't you just put a new steering wheel on the shaft that's on it? I do not have a press. Share this post Link to post Share on other sites
wallfish 18,781 #11 Posted December 25, 2024 1 hour ago, Retired Wrencher said: I do not have a press. That steering wheel is already toast, you don't need a press to remove it. Cut it off 2 1 Share this post Link to post Share on other sites
Handy Don 15,132 #12 Posted December 26, 2024 11 hours ago, ebinmaine said: Jim if that PTO handle hoop and battery box is solid - I'd be interested... @eb, remember I have a couple of battery boxes for you already! 1 Share this post Link to post Share on other sites
ebinmaine 75,689 #13 Posted December 26, 2024 Just now, Handy Don said: @eb, remember I have a couple of battery boxes for you already! Oh I remember. I need at least that and more. Easier to plan for excess and future issues. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,166 #14 Posted December 26, 2024 14 hours ago, wallfish said: That steering wheel is already toast, you don't need a press to remove it. Cut it off John Hope you had a good holiday yesterday! I will if I can not find a set up for it. I have that 1056 running pretty good now. Share this post Link to post Share on other sites
