WNYPCRepair 1,924 #1 Posted December 24, 2024 If anyone has an XI series with a single stage blower, I could really use a picture of the mule drive pulleys and mounts. I kept having my belt pop off, and realized both mule drive pulley brackets are bent and need to see how much I need to bend them back. too bad I didn’t notice in summer when I rebuilt it. 😄 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,471 #2 Posted December 25, 2024 These drawings are usually very accurate. My guess is the flat idler requires most of the correction. https://www.partstree.com/models/79365-toro-42-single-stage-snow-thrower-for-5xi-tractors-sn-200000001-200999999-2000/auger-and-drive-assembly-0/ 1 Share this post Link to post Share on other sites
peter lena 10,020 #3 Posted December 25, 2024 @WNYPCRepair merry christmas ! your call out on on mule drive and related pulleys , are a relatively easy , removal , and service , typically the lubrication fails and causes related drag issues to any belt driven area . like a small pocket flat screwdriver , or very small flat putty knife , for easy side seal removal , wipe out , flush with carb cleaner , like a 550 deg flash point chassis grease , lucas , green , that belt set up gets quite hot / stressed , from every rotational point , its the COLLECTIVE DRAG , of spindles , idler pulleys , that creates the issue , ironically every time you engage your pto drive , its telling you of how easily , or not your entire set up is moving, while I do not have your set up , the basics , still apply , my decks move , easily by hand , at the pto belt drive start area , no squealing , no rough spots , engagement is smooth / easy . don a lot of functional detailing on every movement spot , my tractor supply belts have no fraying , cracks / splits , telling me its moving as it should , pete 1 Share this post Link to post Share on other sites
WNYPCRepair 1,924 #4 Posted December 25, 2024 9 hours ago, gwest_ca said: These drawings are usually very accurate. My guess is the flat idler requires most of the correction. https://www.partstree.com/models/79365-toro-42-single-stage-snow-thrower-for-5xi-tractors-sn-200000001-200999999-2000/auger-and-drive-assembly-0/ yea the flat idler appears to be bent to the left about 1/2”. The other pulley is just slightly bent. I was just hoping for a good picture so I didn’t bend it too far back. Share this post Link to post Share on other sites
peter lena 10,020 #5 Posted December 25, 2024 @WNYPCRepair you probably will not be able or recommended to attempt to straighten out any pulley or rotational part , once that angular rotation starts , its violent action will only help to tear up the rest of the movement cycle . would go on line and look up , hopefully a movement look see to your unit , found a couple of your set up , unfortunately none of the rotational movement set up needed . you need a how to replace pulley / related video . am only familiar with the older style / type , completely different set up , pete Share this post Link to post Share on other sites
Handy Don 17,343 #6 Posted December 26, 2024 On 12/24/2024 at 12:47 PM, WNYPCRepair said: both mule drive pulley brackets are bent and need to see how much I need to bend them back. Ease of manufacture (both in fabrication and quality assurance) would lead me to strongly suggest that both of those arms should be at 90º from their respective shafts. both appear bent to me. 1 Share this post Link to post Share on other sites
