clueless
Anybody use the Krylon Fusion All-in One spray paint on their tractor or wheels? Thoughts.
JAinVA
I have yet to use  Krylon Fusion paint on my tractors but I have I painted the winch bumper on my F250  with it. The paint seems to be consistent from can to can. The color I used was  satin black. and the Krylon was more to my liking than Rust oleum..
I liked the outcome with the Krylon but your mileage may vary.
  • Like 3
Achto
I buy Krylon when I can, like it much better than Rustoleum. The all in one primer / paint works good, but I still use a self etching primer first if I am using it on bare metal.
  • Like 3
953 nut
Chris, you will probably find lots of pros and cons in this thread.
Bar Nuthin
I don't know that I've noticed a quality difference between Krylon Fusion and Rust oleum's Farm and Implement.
One aerosol feature I will bump up is Rust oleum's 5 in 1 adjustable nozzle.  On the wide fan setting you can lay down a really nice pattern if you're looking for a quality finished appearance. There's also a low volume setting that's nice for working in tight spots like wheels or corners. The dry time is pretty slow, though - which is nice for gloss but worse if you have a dirt problem or are impatient and wanting to handle the parts right away.
